Old 04-04-2016, 08:11 AM   #1
Nozzle in toilet won' t spray
I have a 2013 29 IKTS with a Dometic toilet. The nozzle in the bowl only trickles out. I have good water pressure to toilet.
blakevan1962 is offline   Reply With Quote
Old 04-04-2016, 08:28 AM   #2
Head Rambler
It's most likely a plugged valve screen. You'll have to take the water valve off to clear it.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 04-04-2016, 08:28 AM   #3
Flybob's Avatar
You most likely have crud from the water lines clogging the valve. You an try removing the water line from the valve and using some low pressure ( 20psi) to reverse blow out the valve. This is a very common problem and it can also show up in faucets as well. They are easier to fix as they usually only require removing the faucet screen and cleaning it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
