Old 08-06-2016, 12:37 PM   #1
PPST Wannabe
kenandterry's Avatar
OEM water filter or not?
We never, I repeat never, drink water from our on board tank, or when hooked up to any source of "city water". We wash, cook, shower only with the above mentioned sources. For drinking or when it's a key ingredient in cooking we use bottled water.
My OEM water filter unit in the water service bay is labeled as a Water Pur model CCI-10-CLW and says to replace the cartridge with a CCI-10-C model. As with most things RV, some things can be overly expensive, when other like products can be purchased at Lowes or Home Depot.
Do we need a water filter at all?
If so, does anyone have the details of a water filter that could be used in place of the OEM model to just reduce/eliminate sediments without restricting water flow pressure? Where did you purchase it?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 08-06-2016, 01:14 PM   #2
Canadian Member
We bring bottled water for drinking and cooking but use campground water from the FW tank for dishes, showers and brushing our teeth so it probably should be filtered if not purified. If you only camp at provincial parks you can probably trust the water and not use a filter.
I have the same filter housing and I buy the F1Pb filter cartridge from rvwaterfilterstore.com. For all the camping we do, one filter is good for an entire season. If we won't be using the water system for more than 2 weeks, I drain the entire system - filter housing, water heater and all the water lines. I leave the filter in the sink by the door to remind me to reinstall it before leaving for the campground.
2019 Rockwood Signature 8290BS
Old 08-06-2016, 01:23 PM   #3
Ford Idaho's Avatar
I suggest you remove the OEM and bypass it with a threaded coupler.
Like this, Lowes or Home Depot or even a Ace hardware store.
1/2" Schedule 40 PVC Coupling 430-005
Then stop at Walmart and pick up one or two inline filters.
Camco Water Filter, 2 Pack - Walmart.com
This will keep sediment out of the water supply lines and tank and you need not worry about the filter canister coming apart and flooding your unit.
All so makes winterizing a touch easier.
Old 08-06-2016, 02:18 PM   #4
Canadian Member
The filter housing that the OP has is not the one that has problems. That's the FR1.
Old 08-06-2016, 02:33 PM   #5
I still would Remove it from Inside even if it was the "Best in the World"! The way the OP uses their system go with the "Blue Two" from Wal -Mart! Youroo!!
Old 08-06-2016, 02:46 PM   #6
Butch Wilson's Avatar
I use the OEM filter. No problems.
Butch Wilson
2016'Flagstaff T21QBHW A-Frame
Butch Wilson is offline   Reply With Quote
Old 08-06-2016, 02:56 PM   #7
fonzie's Avatar
This will fit your filter housing. I removed my filter housing from inside trailer and use it outside. I'm not taking the chance of a flood inside trailer......
https://www.lowes.ca/water-filtratio..._g1362662.html
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 08-06-2016, 11:39 PM   #8
dmchapman's Avatar
Well, just to be contrary I'll add my 2 cents...We always drink from the FW tank or campground water when available and it all goes through the onboard OEM filter which didn't crack and leak despite not winterizing the unit over the Winter. What, Me Worry?
2015 Microlite 21 DS
2012 Silverado extended cab Z71
dmchapman is offline   Reply With Quote
Old 08-07-2016, 06:15 AM   #9
waiter21's Avatar
We also use bottled water.
As for the filter, one benefit of the filter is to remove sediment and other solids that may be in the hose or supply system.
If you use a standard 10 inch filter, you can bye these at almost any big box store.
I use a string filter at home, mainly to remove sediment (sand), these cost about $2.00 each. I'm not sure how you use your MH, but I would recommend changing it at least once a year, Remove the old filter when you winterize, and install a new filter when you get ready for your first trip next spring.
We change the filter at home every few weeks, depending on water table, (low water table kicks up a lot of sediment)
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-07-2016, 01:18 PM   #10
OEM Water Filter or Not
We also use the Camco 2 pack from Walmart. BTW remember to store the
used filter in your fridge when travelling. We find one filter is good for a
season.
Ian Walker is offline   Reply With Quote
water, water filter
