Old 08-07-2014, 03:11 PM   #1
Oh Boy! Water Works issue!
Hi we are new to this forum/site. We purchased a used 1998 37 foot DP Coachmen Santarra. When I filled the fresh water system everything worked perfect. We have the 5-valve “Water Works” system by Coachmen, (see before/after picture) that I now know is discontinued. This is our first Class A but we have owned 5th wheels with gravity fed water line.
Here is our problem:
I had 2 valves on the Water Works system that leaked and I tried everything to get at them so I could crimp or replace the valve. I could not get at them and the PEX tubing is not forgiving. So the more I thought about it I started to just cut the system out. We do not like the idea of a utility showerhead and the fresh water intake, inside the same bay with the sewer connections. So I figured I would just put a valve on the main line to the fresh water tank and buy some extra PEX tubing and quick connectors and Walla! I’d be all set…..baaaad idea and even worse I did not take pictures of the water valves before I cut all the lines. Ugh.
Now I can fill the water tank using the water line that enters the tank on the right side of the compartment but the pump will not pump water through the system. It’s like it does not have prime. I assumed just like a pull behind trailer as long as the tank was full we’d have water. Fortunately I have the valve system (in pieces) but I have no idea what line goes where. If there is anyone out there with a pluming repair schematic for the Water Works system or someone with the same system that could take some pictures and send them to us I’d be so grateful.
Thank you
ID:	59898   Click image for larger version
ID:	59899   Click image for larger version
Beeper is offline   Reply With Quote
Old 08-07-2014, 09:27 PM   #2
Campin Cajun's Avatar
Do you own an air compressor? You could blow air into the lines that are cut and have a buddy looking at the different faucets or tanks to see which hose goes where. Then once you figure that out you can build your own manifold.
2013 Berkshire 390 BH
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-08-2014, 06:57 AM   #3
Thanks Campin Cajun
There were only 5 valves and/or lines. 1 each hot/cold waterline for the utility outside shower, 1 each for the hot cold water drain line and the winterizing suction fill. With that said….there was a loop or two I think.
I attached a picture of what I cut out. I also called the Coachmen service but they can’t help. If you click on any of the pictures you can zoom in.
ID:	59919   Click image for larger version
Old 08-08-2014, 07:05 AM   #4
Beeper,
Have you posted your question to a Coachman website? Might have better luck. Hope all works out for you.
Gary
tri5ford is offline   Reply With Quote
Old 08-10-2014, 05:50 PM   #5
Can you send me a "link" for the coachmen website/fourm? Thanks
Old 08-10-2014, 06:01 PM   #6
Never mind....I found the website. Thanks
water
