Old 06-09-2015, 04:55 PM   #1
Oh the Smell
Own a 2015 Sandpiper 30IOK
I am getting a very bad sewer smell through my camper when I am flushing the tank. No issues any other time such as flushing the toilet, just when I hook the hose up to the tank flush and run it.
After reading through smelly stories on here, I realize the vent at the top can cause issues, toilets domestic 300(where would I find the model), back flow valve and fantastic fan being on while flushing.
Ultimately I guess the issue may be me needing to clean the tank better, but something seems off. Thoughts?
2019 GMC 2500HD 6.6 Duramax
X96mnn is offline   Reply With Quote
Old 06-10-2015, 07:48 AM   #2
Quick bump, find this odd.
Old 06-10-2015, 07:58 AM   #3
TURBS's Avatar
Model 300 http://www2.dometic.com/enus/America...tdataid=106247
Sometimes threads get buried really fast around here and a thread get missed no and again.
Especially so yesterday since they were doing maintenance.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-10-2015, 08:09 AM   #4
check the forums under plumbing then under 'majic plumbing' its what that rver found
Big Bill is offline   Reply With Quote
Old 07-07-2015, 06:56 PM   #5
Checked the items listed and already had the 310 toilet and checked the connections and all were tight but found the picture posted. Fairly certain the hole in the black tank vent pipe is my issue. Will show this to the dealer but already started the fix on my own. Click image for larger version
Name:	ImageUploadedByForest River Forums1436313364.044544.jpg
Old 07-07-2015, 07:33 PM   #6
WTF? This could not have come from the factory this way could it?
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 07-07-2015, 08:56 PM   #7
RPAspey's Avatar
Wait a minute.. did someone install solar panels on the roof? They look like MC4 cables.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 07-07-2015, 10:52 PM   #8
I had a roof top winegard satellite installed which is one of the cables, rg6. At first I thought they did it but only one cable is theirs, the other I think is the antenna but will need to check more.
Either way the guy installing it should have known something was off. There should not be a one inch hole in the stink vent. I mean methane has leaking into where you sleep.
Have applied the first layer of silicone patching, will build it up to a solid seal, if I thought it could be taken out and made right without tearing the place apart I would do it. I am more comfortable/satisfied with my own fix.
Old 07-07-2015, 10:59 PM   #9
Actually with a better look, one is the rg6 and one is the power for the dish. This was not a factory job, all dish install job.
Maybe I am wrong but I do not think this is right.
Old 07-08-2015, 06:46 AM   #10
as soon as i think ive seen and heard it all , something like this pops up, i wonder how the cables come out on top? iwonder how many more installs were done like this? this reminds me about the dish install on my house, I wwould go viral with this!!
Old 07-08-2015, 01:04 PM   #11
I think a lot more then people know. There are actual videos and instructions on how to do it this way but they do not cut a hole in the pipe. They place a tee in the pipe and a screw on end that is actually designed to run the cable through.
Old 07-08-2015, 05:43 PM   #12
So this t fitting on the bottom how do the wires come out on top?
