Old 04-08-2014, 08:26 PM   #11
davel1971's Avatar
Originally Posted by ironj View Post
what gives? as mentioned my rhino fits with elbow (tabs aligned up and down) as well as my two extension hoses in the other side...and in my in laws trailer they fit, but a lil tight....
but many have said thiers dont fit...so are the bumpers just assembled randomly or what?
Sent from my Transformer Prime TF201 using Forest River Forums mobile app
the whole trailers are assembled randomly
mine is in there, but it takes some work to make it happen. Never had a problem with the cheaper hoses.
David & Lynn
Old 04-08-2014, 08:28 PM   #12
magnmike's Avatar
My rhino fits in my Roo bumper just fine as others have posted. You just have to twist end so tabs fit. Love my Rhino!
2013 Rockwood Roo 23SS
2004 Nissan Armada
magnmike is offline   Reply With Quote
Old 04-08-2014, 08:29 PM   #13
davel1971's Avatar
Originally Posted by HSVBamaBob View Post
Dave,
I was thinking that as well but the 6" PVC is *thick* and (compared to the fencepost) weighs a ton!
I am not usually a weight nazi, but I am putting enough mods on my 5er now to where I am considering weight when I can
your right about that. I haven't gone browsing for a fix yet, but its on my "to do" list. PVC sewer drain pipe is MUCH thinner and lighter than supply PVC pipe. Still plenty of fittings to choose from. Maybe our bumpers aren't truly 4" and it will fit in 4" pipe. Need to do some figuring.
David & Lynn
Old 04-08-2014, 08:36 PM   #14
davel1971's Avatar
obviously not all bumpers are created the same. I will get a measurement on the bumper and see if it falls short of 4". Mine is so tight I'm afraid I will damage it.
David & Lynn
Old 04-08-2014, 08:45 PM   #15
Fulltime family RVer
Two small hinges pop riveted into place and a toggle latch to hold it shut with a pin through to keep it "locked".
Old 04-08-2014, 08:46 PM   #16
Denver, CO
garbonz's Avatar
Mine slides right in my V Cross.
2017 Fuse 23T
Old 04-08-2014, 09:05 PM   #17
jawga's Avatar
Ours slides in also when lining up the tabs with the corners in our wildwood xlite.
jawga is offline   Reply With Quote
Old 04-08-2014, 09:22 PM   #18
Road-King's Avatar
4" PVC didn't work for me. I had some already and just looking at it I thought that it would work.... 1/16th to a 1/8th inch too small... Fold up step ladder will not fit either...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 04-08-2014, 09:38 PM   #19
onetonford's Avatar
This is how I did mine used rivets to close one end and put hinges and latches on the other to swing open so far they work great being next to the drain makes it easy to load also. I put them on at a 1" drop on closed end and drilled several holes for drainage.
Name:	Sewer Hose container 001.jpg
Name:	Sewer Hose container 002.jpg
Name:	Sewer Hose container 003.jpg
Name:	Sewer Hose container 004.jpg
Name:	Sewer Hose container 005.jpg
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 04-08-2014, 09:43 PM   #20
The 5' folding ladder is all I put in our 4" bumper along with a laundry drying board.
Amazon.com: 5 Foot Single Sided Compact Folding Ladder: Home Improvement
modifications
