04-08-2014, 08:08 PM
OK Lets talk Sewer Mods!
So after today's...conversations...:roll eyes:...I went shopping at Lowe's and here is the scoop from my POV:
Rhinoflex with sewer attachments is just over the 4x4' bumper in a RV (OK this is issue #2 I will be discussing with Forest River CEO @ Goshen...)
So the REAL fix is the &^%$@!! Industry needs to make 5x5' bumpers - how the hell hard is that?!
So the MOD is: a 5x5" PVC fence post in Lowe's - 96" long so I will have to cut it down to fit the bumper BUT....
It will hold 3 Rhinoflex tubes - 1 5ft & 2 15ft collapsed with connecters on them. I have glued the 45 deg adapters on the sewer so they are done.
This will hold the sewer and I believe eliminate a sewer box from the basement!
As I see it this will store everything I need - hoses and connectors! All I need is the camp sewer connector (and I can put that in the RV chemicals box)
Issues before I start the mod:
How can I secure the end caps (BIG PROBLEM!) The post has end caps you can buy but they are not press-to fit...they "sit" on top (you are supposed to glue them in place)
The post is 5x5" - if I secure it to the bumper (4x4") what would you use?
OR....should I see about securing it close to the Grey/Black valves?
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
04-08-2014, 08:16 PM
Jack of All Trades
I've had the rhino-flex since I got this TT. It fits in the bumper fine, with the 90* elbow on the discharge, if you line up the "tabs" on the coupler with the corners of the bumper.
Only problem I've had is it slipping too far into the bumper and not being able to get hold of it to pull it out. Solved that issue by making a handle with a long wire-tie (zip tie).
Rick
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
04-08-2014, 08:18 PM
I feel your pain. I just got a new 5th wheel and a Rhino hose to go with it. Its jammed tight in bumper right now, but don't like it. I'm thinking some 6 inch PVC mounted under the TT in front of the axle near the drain outlet. No problems with choices of hardware or end caps for PVC
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
04-08-2014, 08:19 PM
Oklahoma Proud
This is what I did. Put cap on, drilled a whole straight thru, bought some, I believe 8" 5/16 bolts cut off threads, and tapered the end. Drilled a. 1/8 inch hole in it thru the bottom and thru the head ( i was going to add a cable between the clip and the bolt head, havent gotten to it yet) and use a hair pin clip to hold it.
MillerTime- Future Sabre Handler!!
04-08-2014, 08:21 PM
Dave,
I was thinking that as well but the 6" PVC is *thick* and (compared to the fencepost) weighs a ton!
I am not usually a weight nazi, but I am putting enough mods on my 5er now to where I am considering weight when I can
what gives? as mentioned my rhino fits with elbow (tabs aligned up and down) as well as my two extension hoses in the other side...and in my in laws trailer they fit, but a lil tight....
but many have said thiers dont fit...so are the bumpers just assembled randomly or what?
Sent from my Transformer Prime TF201 using Forest River Forums mobile app
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
04-08-2014, 08:22 PM
Oklahoma Proud
Landscape nails might work too, I used a 5" cap on a 4 3/4" post cover, so that way I didnt have to worry about venting the end.
04-08-2014, 08:23 PM
Rick
Hmmm..OK Rick I will check this out - thanks! (post late tomorrow though---it's DARK outside now )
I like the idea, as far as mounting I would leave it on the bumper, less accidental fumes below the trailer, and the bumper will support any weight. I would think of some carriage bolts with some big ol' fender washers and fasten that to your bumper. That will allow for any stress on the plastic to be distributed. (not that there should be much) As far as the end caps, i would use a long stainless bolt (rust resistant) and a wing nut. Drill through both sides of the end cap and post.
Camo Dan
2013 Flagstaff Micro Lite 19FD
2001 Chevrolet Silverado 1500 Ext. Cab 5.3L
04-08-2014, 08:25 PM
Put 2 push button pins on each end of both fence post covers.
04-08-2014, 08:26 PM
the whole trailers are assembled randomly
mine is in there, but it takes some work to make it happen. Never had a problem with the cheaper hoses.
04-08-2014, 08:28 PM
My rhino fits in my Roo bumper just fine as others have posted. You just have to twist end so tabs fit. Love my Rhino!
2013 Rockwood Roo 23SS
2004 Nissan Armada
04-08-2014, 08:29 PM
Originally Posted by HSVBamaBob
Dave,
your right about that. I haven't gone browsing for a fix yet, but its on my "to do" list. PVC sewer drain pipe is MUCH thinner and lighter than supply PVC pipe. Still plenty of fittings to choose from. Maybe our bumpers aren't truly 4" and it will fit in 4" pipe. Need to do some figuring.
04-08-2014, 08:36 PM
obviously not all bumpers are created the same. I will get a measurement on the bumper and see if it falls short of 4". Mine is so tight I'm afraid I will damage it.
04-08-2014, 08:45 PM
Always Learning
Two small hinges pop riveted into place and a toggle latch to hold it shut with a pin through to keep it "locked".
04-08-2014, 08:46 PM
Denver, CO
Mine slides right in my V Cross.
2017 Fuse 23T
04-08-2014, 09:05 PM
Ours slides in also when lining up the tabs with the corners in our wildwood xlite.
04-08-2014, 09:22 PM
4" PVC didn't work for me. I had some already and just looking at it I thought that it would work.... 1/16th to a 1/8th inch too small... Fold up step ladder will not fit either...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
04-08-2014, 09:38 PM
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
04-08-2014, 09:43 PM
The 5' folding ladder is all I put in our 4" bumper along with a laundry drying board.
Amazon.com: 5 Foot Single Sided Compact Folding Ladder: Home Improvement
