Old 12-27-2015, 02:19 PM   #1
OK to use heat tape on dump valves
Is it OK to use heat tape on exterior dump valves on a travel trailer?
If not, any other ideas to keep the valves warm? They are not enclosed, so a light bulb probably will not work. Thanks!
episodic is offline   Reply With Quote
Old 12-27-2015, 02:23 PM   #2
nomad297's Avatar
Heat tape will work. So will heat pads.
Bruce
nomad297 is online now   Reply With Quote
Old 12-27-2015, 02:57 PM   #3
Our unit came with Factory Heat Pad's on the (Tanks/pipes/and Valves) so it must be OK! Youroo!! These are 12 Volt!
valve
