Old 04-11-2016, 12:29 PM   #11
Mountainmanbob's Avatar
Originally Posted by banda View Post
A temporary solution would be to buy a plug that fits the threads of the fitting.
Worked well for us for years on an old motor home we had. A little Teflon tape around the plug threads.
Or just buy a new check valve.
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 04-11-2016, 04:00 PM   #12
I'm not trying to use the onboard water pump when shore-tied with a city water hose. It's when I try to use the 20 gal potable onboard source that the coach pump pushes water out the city connection.
Buy a new valve? I just bought this coach (new) on 4/7 - my punch list grows by the day. I'm finding pinched waterlines. Leaks at the sink / metal basket (not the p-trap), gaps thru the floor, unsealed with that magic expanding foam that's in evidence. The coach battery was down a cup of (distilled) water. . . I have an appointment for 4/23 to return it for " repairs" -- probably have to leave it. There goes 3 maybe 4 weekend camps.
2016251RKS is offline   Reply With Quote
Old 04-11-2016, 04:30 PM   #13
mike.t's Avatar
Sorry. Well if it's going to the dealer then I guess he can answer your questions.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 04-12-2016, 10:13 AM   #14
Originally Posted by mike.t View Post
Must be missing something. I thought you did not use the water pump when connected to city water.
You don't. The pumps only purpose is to pump water from the fresh water tank.
There is a check valve on the water pump. If the pump is not used very often sometimes the valve sticks.
Add water to the tank. Remove the hose from the fill connection. Then open a couple of the faucets. Turn the pump on and off a half dozen times and maybe the valve will unstick. If it doesn't then you will have to remove the pump and take it apart and free the check valve by hand. I have never had to do it but there are a few threads that tell you how to do it. From what I have read it does not appear too hard to do. The hard part is getting to the pump to remove it. Good luck.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 04-12-2016, 10:26 AM   #15
mike.t's Avatar
Sorry again, Exactly what is the OP doing that he noticed this.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 04-12-2016, 12:43 PM   #16
I was was filling the 20 gal potable tank and going to use the onboard water system, after trying the city water hose hook up. Did just what the above postings say. Seems that the internal check valve is no good. Disappointed that it wasn't discovered in the initial delivery walk-thru. Makes me think the system wasn't checked. (yes, even on using the city water, I had the water pressure regulator in the hoseline). Also found a couple of 90* bends in interior water supply lines to sink. Again, too bad this wasn't evident on delivery. Oh well. Appointment made to return trailer at the end of the month for these items.
Retired U.S. Coast Guard Mustang
Presently a librarian @ Duke
Old 04-12-2016, 12:50 PM   #17
mike.t's Avatar
Now I understand. You were testing BOTH water systems.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 04-12-2016, 09:39 PM   #18
Actually you can In fact use the pump when connected to city water. I always keep water in our tank when we are going to be at same place for a bit. We have had the park pressure drop or completely lose water pressure on the city connection. In this case I turn on the pump to increase or take over the water system until the city pressure rises or returns.
Rich5117 is offline   Reply With Quote
Old 04-12-2016, 10:08 PM   #19
Curt and Michele's Avatar
I don't really know how to explain this but will try. On my coach I have what I think is called a wet station. It contains different valves and my outdoor shower in this compartment sealed by a slam latch door. Mine need to be in certain positions to work properly. If yours has this do they need to be set to work properly?
F250 6.7 Diesel 4X4 Crew Cab
2015 Coachmen Chaparral 5th Wheel 336TSIK
Curt and Michele is offline   Reply With Quote
Old 04-14-2016, 10:55 AM   #20
Yes he is checking what should have been done before the walk thru but apparently wasn't done. Not a good dealer in my opinion or these things should have been checked.
Jim
George Bernard Shaw
pump, water, water pump
