Old 08-03-2016, 05:46 PM   #1
dmdomokos's Avatar
On trip and kitchen sink must have a gremlin in it
We are on a trip to Tetons/Yellowstone and my DW is convinced we have a gremlin in out kitchen sink. 4 parks so far with hookups. We are using a 50psi regulator. First park, full pressure bath and shower (actually every park), but sink has a trickle. I checked the aerator, removed the head completely, still a trickle. Checked for kinks, found nothing. Convinced we needed a new faucet. Park 2, a little more pressure, but still not good. Park 3, no pressure, dripping. I was going to replace the faucet at park 4. But then, park 4, about 75% flow day 1. Day 2, full pressure. Told the DW I fixed it, but really never touched it. (She knew better that's why the gremlin comment). What am I missing?
2016 Rockwood 2702WS
2016 Chevy 2500HD Duramax 4x4 High Country
dmdomokos is offline   Reply With Quote
Old 08-03-2016, 06:00 PM   #2
Carknocker Family
Ida Ratherbe Camping's Avatar
I had to take hot and cold valves out and clean. Had a plastic shaving hung in one and faucet wouldn't turn off. This showed up after two years of ownership.
Might try looking there.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is online now   Reply With Quote
Old 08-03-2016, 06:12 PM   #3
dmdomokos's Avatar
Valves? The sink is one unit, you mean valves by the hot water heater?
Old 08-03-2016, 06:18 PM   #4
dmdomokos's Avatar
Name:	ImageUploadedByForest River Forums1470266195.949410.jpg
ID:	116224Click image for larger version
Name:	ImageUploadedByForest River Forums1470266216.216114.jpg
Old 08-03-2016, 06:27 PM   #5
AquaMan's Avatar
There is small insert valve(s) inside the faucet itself that meter the water from the handle.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 08-03-2016, 06:50 PM   #6
dmdomokos's Avatar
How do I get to that? How does this faucet come apart?Click image for larger version
Name:	ImageUploadedByForest River Forums1470268208.646738.jpg
Old 08-03-2016, 08:29 PM   #7
rracer5's Avatar
How do I get to that? How does this faucet come apart?Attachment 116226
On the handle, you will see your little red & blue hot/cold indicator. Pop that little plastic disc out & you will find a set screw to remove the handle. Then you will find the rest of the valve and nut that holds it all together.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-04-2016, 09:00 AM   #8
Thurman's Avatar
In post #2 in the reference to "valves" the poster meant "cartridges". Both single handle and the two handle faucets nowadays have cartridges in them. In post #7 rracer5 is correct on how to remove that particular cartridge. In post #2 the statement "Had a plastic shaving hung in one and faucet would not turn off" is all too common. Don't forget the sink in the bath and the bath/shower faucet also.
Thurman is offline   Reply With Quote
Old 08-04-2016, 12:23 PM   #9
Carknocker Family
They have you headed in right direction, cartridge is the correct term.
Have you checked out yet?
2017 Ram 2500
2014 Salem 32BHDS
Old 08-04-2016, 02:08 PM   #10
BobHanke's Avatar
Check for junk where pullout faucet hose connects to main assembly.
"Lurch" = Georgetown 2011 330TS
Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = NaNa & NiuNiu
BobHanke is offline   Reply With Quote
sink
