01-02-2016, 09:07 PM
One more question
I think I understand winterizing.
I am considering winterizing my RV for a few days. We live in it full time and there are two 8 to 14 degree nights ahead.
If I bypass my hot water heater, since it is located inside (where it is warm), is it necessary to drain it (take the anode out and all that)?
Keep in mind we'll be here and the inside will be warm.
Thanks!
01-02-2016, 09:12 PM
If you keep the water in the heater and on everything should be fine. Unless you lose power or run out of propane.
Why empty it ?
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
01-02-2016, 09:13 PM
Ambassador
Think it's fine if it's inside. usually not the case.
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
01-02-2016, 09:27 PM
Maybe I'm not looking at my water heater. Big white foam enclosed tank under my sink?
01-02-2016, 09:28 PM
Water heater
2014 Ram 3500 DRW
01-02-2016, 09:29 PM
Also, now I'm confused. My manual pretty much says drain fresh tank then put antifreeze in it. Then turn on water pump to pump it through out. I've seen mentioned that you should suck in the antifreeze from outside the fresh line? I'm so confused. Can I just drain the fresh tank and do it from there or not?
01-02-2016, 09:34 PM
You would need a lot more antifreeze. My trailer has a hose like your taking about and I use a 1.5 gallons to treat all my pipes and drains.
2014 Ram 3500 DRW
01-02-2016, 09:39 PM
Since forest river evidently gives a generic manual, how do I get instructions for my model?
01-02-2016, 09:44 PM
You should have a winterizing valve just before the water pump. (if not I would add one easy and about $20). The valve will either draw water from the FW tank or a hose in a antifreeze jug. You bypass the water heater then run the water pump and open each faucet until pink stuff comes out. Don't forget the outside shower and the low point drains. Never put antifreeze in the FW tank, not only will you need many gallons of antifreeze but it is next to impossible to get all antifreeze out. Drain FW tank and leave drain open. a little water in bottom of FW tank will not hurt if drain open.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-02-2016, 09:47 PM
All RVs are about the same, YouTube has a bunch of great videos on how to winterize.
If you winterize you will not have water to anything, toilet, shower and sinks. You need to drain all your tanks grey, Black , fresh and Hot water.
2014 Ram 3500 DRW
01-02-2016, 10:11 PM
Always Learning
It doesn't exist. Unfortunately, you get to learn by doing.
Do you have any winterizing valves? I have one that changes my water pump from drawing in from the freshwater tank to an external hose connection. I change it to the external connection and put a piece of hose into antifreeze.
01-02-2016, 10:23 PM
Canadian Member
Regarding your water heater, although you don't have to empty it if you'll be keeping the tank warm, you should be draining and cleaning it periodically so this might be an ideal time to do that. You'll need one of these.
http://www.amazon.com/Camco-11691-Wa...ds=Camco+11691
If you have a Suburban WH, you'll need to check the anode periodically, too.
01-02-2016, 11:52 PM
never mind!
01-03-2016, 02:04 AM
Just a member
Unnecessary, especially if you're gonna be residing in the RV and heating it. Your fresh water supply may require some consideration but unless the daytime temps are consistently well below freezing, you should be fine.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
01-03-2016, 02:55 PM
Thanks for all the thoughts.
