Old 05-17-2016, 05:06 PM   #1
Only warm water
Got our wolf pup 16bhs in February. Just got back from our second trip and noticed the hot water isn't hot, just warm. Checked all the valves per diagram on this forum and everything is correct. We only use the electric supply, not the gas. Will it be hotter by using gas or both at the same time? Is there an adjustment to make it hotter? Any help is appreciated.
Sfogle is offline   Reply With Quote
Old 05-17-2016, 05:14 PM   #2
Flybob's Avatar
Water heater has a fixed thermostat. Check the outside shower if you have one. If the faucets are on and the spray head shut off, it will allow cold water to mix with the hot. Also check to insure that WH bypass valve is perpendicular to the pex.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-17-2016, 05:32 PM   #3
Please disregard this post. Upon second inspection bypass valve was open. Next trip in 2 weeks and hopefully we'll have hot water
water
