05-23-2018, 07:54 AM
Order of items
What order do I use when connecting a water pressure reducer, external water filter and drinking hose to move TT?
Kevin, Julie (DW), 5 kids
2017 Roo 233s towed with 2016 Dodge RAM 2500
05-23-2018, 07:58 AM
My pressure reducer stays on the trailer. The filter in on the camp hose pib and hose is in the middle.
05-23-2018, 08:07 AM
Typically I see Spigot->Pressure Regulator->Hose->Filter->Trailer
Due to the way my hose routes on the new rig, when I used it for the first time last weekend I had to go Spigot->Pressure Regulator->Filter->Hose->Trailer.
Really though, it doesn't make a big difference overall. As long as you have all parts in line between the spigot and the trailer. The only real difference is that the regulated pressure is downstream of the regulator. Most parks, I've found there's not usually high enough pressure to really worry about needing to protect the hose, but I'll also typically see if it seems to be high pressure when I flush the spigot for a second before hooking up.
05-23-2018, 08:30 AM
Thanks for the tip. This forum is awesome for everyday ideas that might not occur to me. And yes, I put the regulator and filter at the spigot mainly to minimize the weight where the hose screws into the city water.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
05-23-2018, 08:38 AM
Thanks everyone.
05-23-2018, 08:48 AM
Grammar Pedant
Anything you might want to protect from the CG's high pressure needs to be downstream of the regulator.
Nothing wrong with putting the regulator on the trailer, but it means that your hose, filter, and anything else is exposed to the high pressure. I've seen pictures of ballooned hoses. Water hoses are only ~$15 at Walmart, but I think it's just as easy to put the regulator at the spigot.
As for the filter, I'd want it to be at the end of the line. I don't want to filter water, then run that water down a hose, and then drink it. I'd rather run the water down the hose, filter it, and drink it. The closest you can get the filter to the point of use, the better.
Good luck.
Former RV: 2018 Rockwood Mini Lite 2504S
With pressure regulators.... it depends.
Always use it unless the campground already has one on the spigot OR the campground tells you that they have low water pressure. If you use the pressure regulator with low water pressure, you probably won't have pressure inside the trailer.
It should be the first connection on the spigot or you risk rupturing your hose or water filter. Friend ruptured a hose that way.
2015 Dynamax REV 24TB class C
05-23-2018, 04:55 PM
I don't think it matters.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
05-23-2018, 05:41 PM
Here’s the sequence I’ve chosen for us - mainly to keep the regulator and filter behind a closed door.
05-25-2018, 05:40 AM
Originally Posted by Mr. Dan
Here’s the sequence I’ve chosen for us - mainly to keep the regulator and filter behind a closed door. Attachment 173091
Your campers lined are protected. But the day you hit high pressure and split the filter, that bay will be full of water.
I'd be tempted at least to swap the regulator and filter around.
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
05-25-2018, 05:50 AM
Thanks again. If I'm on City water, my pump does not need to be on, correct?
"On the road again"
My pressure regulator is just before the fifth wheel connection, so it's...
Spigot -> Filter -> Zero G hose (love that light-weight, flexible hose for storage) -> Pressure regulator - > Trailer.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
05-25-2018, 05:51 AM
"On the road again"
Correct.
Georgetown XL 378TS
