Old 05-23-2018, 08:54 AM   #1
Order of items
What order do I use when connecting a water pressure reducer, external water filter and drinking hose to move TT?
Kevin, Julie (DW), 5 kids
2017 Roo 233s towed with 2009 GMC Sierra 1500 Crew Cab
kevin79 is offline   Reply With Quote
Old 05-23-2018, 08:58 AM   #2
cavie's Avatar
My pressure reducer stays on the trailer. The filter in on the camp hose pib and hose is in the middle.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-23-2018, 09:07 AM   #3
Kaadk's Avatar
Typically I see Spigot->Pressure Regulator->Hose->Filter->Trailer
Due to the way my hose routes on the new rig, when I used it for the first time last weekend I had to go Spigot->Pressure Regulator->Filter->Hose->Trailer.
Really though, it doesn't make a big difference overall. As long as you have all parts in line between the spigot and the trailer. The only real difference is that the regulated pressure is downstream of the regulator. Most parks, I've found there's not usually high enough pressure to really worry about needing to protect the hose, but I'll also typically see if it seems to be high pressure when I flush the spigot for a second before hooking up.
Old 05-23-2018, 09:30 AM   #4
MillMitch's Avatar
Thanks for the tip. This forum is awesome for everyday ideas that might not occur to me. And yes, I put the regulator and filter at the spigot mainly to minimize the weight where the hose screws into the city water.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 05-23-2018, 09:38 AM   #5
Thanks everyone.
Old 05-23-2018, 09:48 AM   #6
Grammar Pedant
67L48's Avatar
Anything you might want to protect from the CG's high pressure needs to be downstream of the regulator.
Nothing wrong with putting the regulator on the trailer, but it means that your hose, filter, and anything else is exposed to the high pressure. I've seen pictures of ballooned hoses. Water hoses are only ~$15 at Walmart, but I think it's just as easy to put the regulator at the spigot.
As for the filter, I'd want it to be at the end of the line. I don't want to filter water, then run that water down a hose, and then drink it. I'd rather run the water down the hose, filter it, and drink it. The closest you can get the filter to the point of use, the better.
Good luck.
TV: 2005 F150, 5.4L, Tow Package, 4WD
Current RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 05-23-2018, 09:48 AM   #7
With pressure regulators.... it depends.
Always use it unless the campground already has one on the spigot OR the campground tells you that they have low water pressure. If you use the pressure regulator with low water pressure, you probably won't have pressure inside the trailer.
It should be the first connection on the spigot or you risk rupturing your hose or water filter. Friend ruptured a hose that way.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 05-23-2018, 05:55 PM   #8
I don't think it matters.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 05-23-2018, 06:41 PM   #9
Mr. Dan's Avatar
Here’s the sequence I’ve chosen for us - mainly to keep the regulator and filter behind a closed door. Click image for larger version
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 0; booked = 14
Old 05-25-2018, 06:40 AM   #10
XenoRev's Avatar
Originally Posted by Mr. Dan View Post
Here’s the sequence I’ve chosen for us - mainly to keep the regulator and filter behind a closed door. Attachment 173091
Your campers lined are protected. But the day you hit high pressure and split the filter, that bay will be full of water.
I'd be tempted at least to swap the regulator and filter around.
2018 Salem 27DBK
2004 Ram Quad 1500
Days past:1996 Coachman Capri-Ruby Ed. 27DS
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3
XenoRev is offline   Reply With Quote
