Old 08-23-2018, 02:04 PM   #1
Outdoor hose connection problems
I have a Sandpiper 35ROK and have noticed that the 2nd outdoor hose connection is not working. The hose works fine in the main connection where the valves are located but nothing happens at the 2nd connection when I try it.
Any ideas ?
Help!!!
kfk120 is offline   Reply With Quote
Old 08-23-2018, 02:30 PM   #2
brookstone345sa's Avatar
Is the second connection a black tank flush?
brookstone345sa is offline   Reply With Quote
Old 08-23-2018, 02:56 PM   #3
Just as confused as you
Scrapper's Avatar
Or second connection could be a winterizing connection. In either case, there should be a label next to the connection stating what its use is.
Richard & Jill
Old 08-23-2018, 03:16 PM   #4
fonzie's Avatar
This video explains hook ups....
Fonzie
Old 08-24-2018, 01:54 PM   #5
The second connection is another connection for the outdoor shower/hose. It is on the entry side of the trailer
Old 08-24-2018, 01:57 PM   #6
No it is not the black tank flush. It is another connection for the outdoor shower/hose
Old 08-24-2018, 01:59 PM   #7
It is another connection for the outdoor shower/hose. It worked initially but is not working now
Old 08-24-2018, 02:00 PM   #8
Any ideas ?
Help!!!
This connection is another connection for the outdoor shower/hose. It no longer works and I am trying to figure out why & how to repair it.
Old 08-24-2018, 02:04 PM   #9
Can you take off the showerhead and see if it is clogged? Is there perhaps a filter on the inlet that is clogged?
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-24-2018, 02:05 PM   #10
fonzie's Avatar
Post a picture if you can.
Fonzie
Old 08-24-2018, 02:22 PM   #11
Coach
There is usually a check valve on the back side of those ports, could yours be jammed in some way? Assuming all water valves are open.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 08-24-2018, 02:28 PM   #12
Everything works fine when it is connected to the other connection where the valves are located
Old 08-24-2018, 04:55 PM   #13
New to FR. Old to TT
we have that connection on our CC
and the first time I tried to use it , the plunger that holds the water back was stuck . Pushed it in with a screw driver, got sprayed but then all worked after that. Yours maybe stuck, will the connection snap in? They use a High Flow 1/4" air snap on fitting for those hoses, took some time to find the right one. So now we have a shower hose in the water bay and one we use for rinsing off thing by the door or front of the 5th wheel
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
Tall frog is offline   Reply With Quote
door
