Old 06-24-2018, 10:43 PM   #1
Outdoor Kitchen Faucet!!
I have a 29BH with the outdoor kitchen, well the faucet drips continuously, is there any water shut off valves going to this sink until I can change the faucet, or is there a way to fix this issue without replacing the whole faucet?
rjputnam is offline   Reply With Quote
Old 06-25-2018, 08:23 AM   #2
Adony's Avatar
replaced faucet
I had the same problem but my faucet had frozen.. NO SHUT OFF VALVES.. Had to remove entire enclosure to replace faucet..Have never used this outdoor faucet again.. can't even trace supply lines to install shut off valves inside trailer as they go directly under shower / tub..and go to??? poor design.. Wildwood t-25KS
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 06-25-2018, 08:25 AM   #3
Flybob's Avatar
No shut off, that would add to the cost of the unit. Best solution is shut down water system, remove faucet and replace it with a brand name from a big box store.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-25-2018, 08:45 AM   #4
Muletrain's Avatar
I noticed that my exterior shower faucet was also leaking with no pressure in the system. It is low in the system so I figured it is just static water pressure on it. I exercised the hot and cold valves and closed the push pin in the head (like the indoor shower faucet) and now no leaks even with system pressurized.
Not sure how much you utilize the exterior faucet, but if you are like me and seldom do, sometimes just rotating the handles can help reseat the seals.
Mule
Muletrain is offline   Reply With Quote
door, faucet, outdoor kitchen
