Old 06-16-2016, 11:23 AM   #1
Outdoor Shower Help
We were going to use our outdoor shower for the first time. Hooked up to city water. Went to go turn shower on, no water came out. Took off shower head and still no water. Looked behind it and did not see anything that looked like a valve that would be causing the trouble. Any help, ideas, tips would be greatly appreciated. Thanks
mhc02 is offline   Reply With Quote
Old 06-16-2016, 11:35 AM   #2
There's usually a shutoff button on the shower head itself. Did you make sure that was open? You push it one way to open and the other way to close. (Your indoor shower head should have one, too.)
Allows you to turn off the water while you soap up without having to mess with the faucets and screw up your temperature setting.
2011 Traverse LT, 3.6L, FWD
Old 06-16-2016, 12:10 PM   #3
If your shower is on the same side as the bathroom (mine is) look under the bathroom sink (you may have to remove a small panel). There may be shutoffs under there. Mine has them. I am second owner so I don't know if it came that way or was modified for winterizing by the previous owner.
limblips is offline   Reply With Quote
door, show, shower
