Old 11-01-2012, 12:06 PM   #1
psgrandpa1's Avatar
Outside Lowpoint drain
Can someone tell me what all drains to this outside Lowpoint drain
I am getting ready to winterize and not sure what all goes to this point...
If you have dues Gordone for winterizing please let me know thanks friends
If you have winterizing helps and/or do not do please let me know thanks if you have winterizing dues or donuts please let me know thank you if you have winterizing dues or donuts please let me know thanks friends
Bryan & Vonnie MATHIESEN
Hollister MO
Retired 2011
2017 SUNSEEKER MBS 2400W
2013 HONDA FIT SPORT
psgrandpa1 is offline   Reply With Quote
Old 11-01-2012, 08:55 PM   #2
dsotmoon's Avatar
I may be wrong, and it's quite possible since I am new to this, but I think the low points only drain out the freshwater plumbing. ???
Joe
Salem, VA
2011 Dodge Ram
2013 Rockwood 8319SS
dsotmoon is offline   Reply With Quote
Old 11-01-2012, 09:11 PM   #3
B47
I was able to follow your first two sentences, but your last paragraph has my head spinning.
Old 11-01-2012, 09:55 PM   #4
VinceU's Avatar
Yes, in the 378 the two plugs outside near the FW tank and pump will drain hot/cold water lines on one plug and the FW tank with the other plug. I use a air connector to hose adaptor on the inlet connector for city water. Then blow one faucet at a time. Remove hoses from washer dryer and blow those connections into a bucket. Remove large plug in front of washer behind the kickplate. Have a towel handy about 1 pint of water will come out. Check this forum search line for winterizing tips! Good luck with it. Read your refrig book if you have ice cuber and water on door.
Old 11-01-2012, 10:32 PM   #5
psgrandpa1's Avatar
Good grief !...I dictated this message as traveling down the highway...And it looks like there was a lot of interference....
For those of you who figured how what I was getting at, thanks for the response.
I was saying do's and don't 's....must must have been thinking about donuts.
We checked weather forecast for low temps and decided we could get one more short trip before winterizing!
Old 11-03-2012, 06:07 PM   #6
VinceU's Avatar
Two plugs = drains piping and FW tank. Larger tube tank overflow.
Old 11-03-2012, 08:32 PM   #7
bikendan's Avatar
it also will help a lot, if you post the year, make and model of RV, when asking such a specific question like this.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
