Outside shower valve
I have a 2007 Rockwood 2603S that was stored in mildly freezing temperatures this past winter - down into the 20s or even high teens, nothing below zero. I winterized the unit and left all of the fixture valves open. Or so I thought. Apparently I did not open the hot valve fully on the outdoor shower. When hooked up to city water it became apparent that the valve had broken and been dislodged from the body of the fixture.
My question is this - is this valve going to be easy to replace? The existing damaged valve does push back in but does not stay in under any water pressure. Hardly surprising considering it is broken. I do not see any damage to the body of the fixture, but I am hardly an expert.
I would be happy if there was a shutoff for the lines running to the shower as we have never really used it, but I have yet to find such a thing. I was also thinking of a rubber expansion plug to plug the spot where the valve goes. Any thoughts or suggestions on this?
Thanks!
Mark
2007 Rockwood 2603
