Old 01-05-2019, 09:57 PM   #1
P-Trap repair
I have a 266 rlds surveyor : have had the p-trap repaired twice, but still leaking. This would be under the shower. Any help or info on how to fix this problem myself would be appreciated.
Sweetyplum is offline   Reply With Quote
Old 01-05-2019, 10:10 PM   #2
NMWildcat's Avatar
I had a previous RV with the same problem. Due to improper pipe alignment there was stress on the p-trap joint and the vibration during travel days would cause it to loosen/break and leak.
I had enough straight pipe on the exit side of the trap that I could cut and install a very short section of rubber pipe (like radiator hose) with hose clamps. This removed the tension on the joint and I had no more problems.
You can check for stress by disconnecting the p-trap at the collar and seeing if the two sides don't line up or separate.
Hope your problem is as easily fixed. Good luck!
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 01-05-2019, 11:20 PM   #3
Scoundrel
HangDiver's Avatar
Had a cracked drain pipe (also misaligned). Stuck Eternabond Tape on it & no more leaks. That stuff is amazing.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 01-06-2019, 09:12 AM   #4
A32Deuce's Avatar
I used dense foam to support under the shower floor and the drain pipes. Stopped flex and breakage/leaks after I fixed the broken trap.
A32Deuce is online now   Reply With Quote
Old 01-06-2019, 09:15 AM   #5
cavie's Avatar
Flex Tape. There is no pressure on a drain so Flex Tape will fix the problem very well.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
repair
