Old 06-10-2013, 06:59 AM   #1
billt01's Avatar
Palomino Solaire 317BHSK
Does anyone know where the Water filter is located on the 317BHSK to see if it has been installed? I received a wrench with the owners manual, but I cannot seem to locate the filter.
billt01 is offline   Reply With Quote
Old 06-10-2013, 07:34 AM   #2
TURBS's Avatar
It'll be right next to your water pump if you have an idea where it is.
Turbs
Old 06-10-2013, 07:45 AM   #3
billt01's Avatar
I appreciate that insight....Our PDI was less than helpful...I knew more about the TT by reading on the forum from the last few weeks than our tech did. One thing that I did not find on here was the location of the water filter. I do have a hidden access point outside the shower that it might be located in, but have yet to start taking it apart to look for it.
Turbs
Old 06-10-2013, 08:14 AM   #4
TURBS's Avatar
Normally the water pump is right behind where your city water and fw fill station is but inside camper.
May be behind a hidden panel or in a cubby.
Turbs
Old 06-10-2013, 10:13 AM   #5
Marshmstr1's Avatar
On my 269 it's located behind a panel where the park water connection is.
Marshmstr1 is offline   Reply With Quote
Old 06-10-2013, 12:04 PM   #6
billt01's Avatar
not to hijack my own thread...but is it possible to bypass this filter and use one that s inline with the city hookup from the site?..If so what are the particulars...
Old 06-10-2013, 12:08 PM   #7
Marshmstr1's Avatar
I don't use built in filter, it stays bypassed. I use a inline filter on my hose. It's to easy vs removing items in storage, unscrewing panel, wedge myself inside to change built in filter.
Old 06-10-2013, 12:19 PM   #8
billt01's Avatar
Being a newbie here.....whats the best way to "bypass" and use the inline...
Old 06-10-2013, 12:23 PM   #9
TURBS's Avatar
I've said this before but you have to be very careful when buying inline filters as there micron ratings tend to be in the 30+ RANGE which isn't filtering much at all.
I have a chart in the library that shows micron ratings and what they filter.
Turbs
Old 06-10-2013, 12:34 PM   #10
billt01's Avatar
Thank you..
I think I will use and replace the stock filter (when I can locate it...)
Turbs
