Old 03-01-2015, 01:03 AM   #1
Taranwanderer's Avatar
Pex tubing question
So I was preparing for de winterizing the camper today--I flipped all my winterizing valves back over to their "service" positions. Here's the issue: when I flipped one of the valves on the HWH, the whole valve "spun" on the pex tubing. Like, here's a section of pex, then the valve with the metal pex clamp, and then another section of pex with the clamp, and the whole valve/fitting can spin on the 2 pieces of pex. Is this normal, or is this sucker gonna leak like a sieve when I run water through it? I've never assembled anything with pex tubing, so I'm not sure how it supposed to act.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 03-01-2015, 08:53 AM   #2
WFD
Did it leak before you went to winterize it?
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 03-01-2015, 09:19 AM   #3
Hoglou's Avatar
Could you reach the ftting with a pair loppers or hedge clippers? Meaning that if you can reach it you can clamp it then go ahead a get a pex tool and new clamps. See my misc album for what I did. I am not plumber by trade but stick with the crimp style clamps that look like a wedding band (1/2" apollo pro crimp APXCR12LT) and brass not plastic fitting (like apollo APXE121210K).
It is very very easy to work with, the only thing is that once a joint is made it cannot be salvaged. Think about how pvc pipe is scraficed in length when you replace something.
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 03-01-2015, 09:41 AM   #4
I've used the shark bites in tight places on our last 5th wheel
Sent from my SM-N910V
mustardbucket107 is offline   Reply With Quote
Old 03-01-2015, 09:48 AM   #5
WFD
The Shark Bites work amazingly well. I had to some mods to the plumbing when I removed the onboard water filter, and it was a real tight spot to work in, so made getting pex tools in there difficult. RV tech I spoke to said to use the Shark Bites, thats all he uses now when doing plumbing repairs, quick and simple, and they hold really well.
Old 03-01-2015, 09:49 AM   #6
As crazy as it sounds, its normal. According to a plumber I know, they spin a little more when cold, but shouldn't leak. Warmer temps tighten them up. Hope I answered your question.
Old 03-01-2015, 09:51 AM   #7
WFD
Interesting! Thats why i was asking if they leaked before he went to winterize it.
Old 03-01-2015, 09:56 AM   #8
davel1971's Avatar
I always check to see if the system will hold pressure using my air compressor set around 40psi. I don't have anything to clean up if air leaks out.
David & Lynn
Old 03-01-2015, 09:58 AM   #9
To be on the (Safe/Dry) side use (Regulated AIR) instead of WATER for your Test! Yes some Pex fitting turn and do Not leak,but some DO leak? Youroo!!
Old 03-01-2015, 10:30 AM   #10
The pex in my rv and my home will spin and I have never had a leak.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-01-2015, 11:13 AM   #11
It did not leak during usage last year nor when I winterized it in November. Let's hope it is due to the cold as has been suggested. Testing it with air once I get to FL is a great idea. Thanks!
Old 03-01-2015, 11:16 AM   #12
davel1971's Avatar
I just hook and to it and let it sit while doing something else. If there is even a small leak, the compressor will kick on at some point to refill tank. If never comes on. All good
David & Lynn
