Old 03-17-2019, 06:19 AM   #1
Traveling fools's Avatar
Pipes
We picked up our 2019 salem forest river yesterday and had it delivered to our permanent site. For now we are dry docking. Here is my question when we turned on the water and also used the toilet the pipes made a horrible loud rumbling sound. It's very loud so I'm thinking this is not normal. Does anyone out there have a clue as to what this could be. Where I bought it is closed today. Thank you
Traveling fools is offline   Reply With Quote
Old 03-17-2019, 06:31 AM   #2
cavie's Avatar
Water pushing air out of the lines. open all the faucets one at a time and flush the toilet. one all the air is out it will stop. Be very sure to fill the WH before you turn on the electric side of it.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-17-2019, 08:28 AM   #3
Sorry to sound ignorant. This is our first camper. I dont remember him saying anything but turn on power and water tank.
Old 03-17-2019, 08:36 AM   #4
bubbles's Avatar
Sounds like you are hearing the water pump doing its thing. Normal.
Old 03-17-2019, 08:55 AM   #5
Did you do a PDI walkthrough before it was delivered?
2010 Nissan Frontier Crew Cab long bed 2WD
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 03-17-2019, 08:58 AM   #6
Flybob's Avatar
Sounds like you are boondocking and running from fresh water (FW) tank. The sound you are hearing is actually vibration of the water pump and is normal. If you eventually connect to public water the pump will no longer be required.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-17-2019, 09:13 AM   #7
Yes we did... but we dont remember it being so loud during the walk through... that's why we were wondering if we left off a step ...
Old 03-17-2019, 09:56 AM   #8
PPST Wannabe
kenandterry's Avatar
Ok.....quick question here.
Are you connected by a hose to the campground water source or are you using water from your fresh water tank which needs the pump?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 03-17-2019, 11:49 AM   #9
Yes.. we have it on a new property with no power,water yet...just running off batteries and propane..
Old 03-17-2019, 11:59 AM   #10
Flybob's Avatar
Since you said you are new. Keep an eye on your battery levels. Depending on what you are running you can drain the battery quickly. Furnace especially requires a considerable amount of power. Once you connect to water you will no longer require the pump and it will be quiet.
TST Tire Monitors
2 100W solar panels
