Old 09-25-2014, 06:27 PM   #1
Plugged Toilet
Water standing in toilet - will not flush - flush valve opens. If black tank valve is opened and tank flush run, clear water comes out drain valve so I assume tank drain is not plugged.
Tried snake down toilet, tried plunger, tried water pressure. Nothing seems to help. 8285WS 2008 Thetford Tiolet
cadman99 is offline   Reply With Quote
Old 09-25-2014, 06:54 PM   #2
Isn't it just a straight drop into the tank from the toilet? I would think that if you use the sani flush and clear water is running out that the pipe from the tank to the outlet is clear and the blockage is obviously from the toilet to the tank, I would suggest to put on the gloves and dig in.
Mike, Lisa and Jake
2002 Ford F250 CC 7.3
2013 Wildcat Sterling 32RL
MMattox is offline   Reply With Quote
Old 09-25-2014, 07:01 PM   #3
Kaadk's Avatar
I concur. Nasty as it sounds, you're going to have to get a stick and stir it up from the toilet.
Old 09-25-2014, 07:02 PM   #4
Protect your self, gloves and safety glasses are a must have.
Mike, Lisa and Jake
Old 09-25-2014, 07:26 PM   #5
BooBoo23's Avatar
I read somewhere on a forum that someone had one of those black tank cleaners installed (two of them) and one of the cleaners was installed right under the pipe from the toilet to the tank and chunky stuff and TP got hung up on it. They had to remove it to get a clear shot into the tank.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 09-25-2014, 07:34 PM   #6
Yes it looks like a 3" pipe almost straight to the tank - cannot figure out what is blocking it - Will continue with a snake for now. Next choice is to pull the toilet.
Old 09-25-2014, 07:49 PM   #7
jrlogan10's Avatar
I'm having the same problem with my 8289WS. When I snake it it gets caught on something at the top of the tank. It's not plugged now, and liquids go down fine. But the minute toilet paper goes down, you can hear the pipe start to fill up.
2014 Rockwood 8289WS
2003 Silverrado CC Long Bed 8.1L Engine
jrlogan10 is offline   Reply With Quote
Old 09-25-2014, 08:14 PM   #8
Finally took a 1/2" stick about 5' long and beat on it very hard. Whatever it was it was very hard. Now I will wait for whatever it was to plug the tank drain.
Thanks - Don
Old 09-25-2014, 08:16 PM   #9
Ford Idaho's Avatar
It could be the plug from when they cut the hole in the tank and did/do not bother to fish it out.
Some time the plug gets stuck at the tank drain hole.
Old 09-25-2014, 08:25 PM   #10
Assistant TP Supervisor
B and B's Avatar
the 8289 has an elbow at the bottom them attaches to the tank, not sure if it is a 45 and a 90 or 2 45's. Mine is clear just flush with lots of water before dumping to make sure it is clear.
Brian
B and B is online now   Reply With Quote
