I have 2007 forest river Georgetown class a 338. When I turn on the pump to use the fresh water tank, the water pumps out of the city fill connection. What is the problem?
The check valve is attached to the city inlet. It is 1/2 inch threaded and is very easy to replace. All you need to know is it recessed or surface mounted.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
