Old 03-07-2012, 10:49 PM   #1
Plumbing help
I have 2007 forest river Georgetown class a 338. When I turn on the pump to use the fresh water tank, the water pumps out of the city fill connection. What is the problem?
Mposey is offline   Reply With Quote
Old 03-07-2012, 10:53 PM   #2
TURBS's Avatar
there is a one way check valve in the city water connection that sounds to be stuck or broken .
Old 03-07-2012, 10:53 PM   #3
caper's Avatar
You need to replace the check valve at the city fill connection.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-07-2012, 10:53 PM   #4
Dave_Monica's Avatar
The check valve at the city water connection needs to be replaced.
Dave
Beat me to it, twice!
Old 03-07-2012, 11:03 PM   #5
TURBS's Avatar
Dave
dave your slackin !
Old 03-07-2012, 11:04 PM   #6
caper's Avatar
Dave, great minds think alike. Looks like we hit the send button about the same time.
Terry and Janet
2007 Ford F150
Old 03-07-2012, 11:13 PM   #7
Is the check valve part of the city water connection which ties into the plastic pipe?
Old 03-07-2012, 11:26 PM   #8
Is the check valve part of the city water connection? Do I simply remove this connection and replace with a new one back into the plastic pipe?
Old 03-07-2012, 11:41 PM   #9
TURBS's Avatar
Should be close to city water connection
But I've seen them right next to the pump
Old 03-07-2012, 11:42 PM   #10
TURBS's Avatar
You'll have to follow the line from pump to your city water connection
Old 03-08-2012, 12:21 AM   #11
caper's Avatar
The check valve is attached to the city inlet. It is 1/2 inch threaded and is very easy to replace. All you need to know is it recessed or surface mounted.
Terry and Janet
2007 Ford F150
Old 03-14-2012, 10:29 PM   #12
TURBS's Avatar
did you get it fixed ?
