Old 03-19-2016, 10:45 AM   #1
Adony's Avatar
Plumbing Leak..Good or Bad Idea to fix...
My kitchen sink is located in the slide out. The slide out is connected to the trailer main frame using a flex line but from there to the faucet, it is PEX. When the trailer was new, the hot water connection to the faucet leaked and was fixed under warranty. They first tried tightening the fitting but eventually had to replace a gasket. Disconnecting the red PEX from the faucet was easily done but due to the rigidity of the PEX and the extremely limited access access to the faucet bottom, they ended up taking the sink out to make the PEX / faucet connection without cross threading the fitting. Now the same thing has happened to the cold water connection. Tightening the fitting did no good. I am sure my arm will reach to disconnect the PEX fitting on the bottom of the faucet but putting it back on and getting it aligned before threading the fitting on is a different story. Not only is the PEX rigid but has no slack to spare. GOOD OR BAD IDEA... connect a regular house type faucet flexible line to the faucet which should be easier to install, cut the PEX pipe back a foot or two, install a shark-bite in line stop valve and then connect the flex line to the faucet to it. Just a thought in case leaks develop in the future I would not have to secure the water to then entire trailer.. Same could be done for Hot water side.. Just wondering??? The photo is looking up and where the leak is where you can't see it directly from where you get under the sink.. a long arm will reach the fitting but would be difficult to reinstall the fitting without being able to see what you are doing
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 03-19-2016, 04:10 PM   #2
Well, I've seen some with less space where you can't even turn a wrench. However, think your idea to add a "pigtail" is sound.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
leak, plumbing
