01-28-2014, 02:28 PM
Plumbing Lines
I took a picture of my plumbing near the pump and am trying to figure out what and where the water lines go. Since they don’t provide a diagram and I can’t see where the lines go throughout the camper, I am guessing here. Do you agree or disagree with what I have so far?
John
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
01-28-2014, 02:41 PM
John,
I believe your city water in is the hose going to your hose coming in from fw tank that you have a question mark by.
TURBS
oc's buddy
01-28-2014, 03:15 PM
pump
A pump has a suction and a discharge. usually you cannot run the flow backwards through a pump. So I think the dark blue line goes to the waterheater and the other to cold on faucets. One side of the pump is intake the other side is discharge.
01-28-2014, 03:42 PM
I agree with turbo. City water arrow should point to the line with the question mark and connects up with the line marked from tank. I believe the black thing where the two meet is a two way valve that pulls water from the tank if there isn't any pressure from city water. The outlet of the filter, is the blue line that feeds the cold water to sinks, etc. and the other white line feeds the water heater..
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
01-28-2014, 03:57 PM
So here is the updated image. The blue line is where the water filter was. You can see the two mounting holes in the aluminum above it. If this drawing is correct then FR only filtered the cold water?
Ohio
2015 Ford F-350
4WD SRW Diesel
01-28-2014, 04:11 PM
Hey I am not buying the ? is City water in.That is the Suction side of the Pump. I would more believe it to be A/F inlet.The other hose is F/W tank coming to the Suction side of the Pump. Youroo!!
01-28-2014, 04:31 PM
Ok. Now I'm confused. As I look at it further I'm not sure what you have. Did you take out the water filter? On my trailer I have a single line from the tank to the inlet of the pump. On the outlet side I have the outlet of the pump feeding a two way valve and also the hose from city water which is filtered. If there is pressure from city water the valve pulls from there. No city water, I turn on the pump and it pulls from the tank and closes off the feed from the city inlet. The valve feeds the cold water faucets and the hot water heater.
2012 Sabre 250RLUD
Max Tow, 6.2, 3.73
01-28-2014, 05:33 PM
My city water tees into the fw tank line I believe.
I'll look .
TURBS
oc's buddy
01-28-2014, 05:34 PM
Here is a picture before the filter was removed. The filter simply was installed in the blue line I have now.
Ohio
2015 Ford F-350
4WD SRW Diesel
01-28-2014, 05:42 PM
Carknocker Family
I believe that you have everything listed correct in the second pic. the filter only filtered the water going to the sinks. The hot water heater supply did not run through the filter. Just used the metal screen in front of pump to catch the big hunks.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
01-28-2014, 06:05 PM
Jack of All Trades
I disagree!
I think your picture in the first post is correct, with the line with the question mark being the antifreeze suction line.
Why? To the inlet side of the pump (if you look close you can see the suction strainer) one line is from the tank the other line would not be the city fill. The city line does not go through the pump. Thus, the other side of the pump is the discharge. The pump discharge line goes to one side of the tee and the city fill goes to the other side of the tee. The tee branch connection then goes to all the cold water faucets AND the water heater. The integral check valve in the pump prevents the city fill from flowing backward through the pump to the tank.
Rick
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
01-28-2014, 06:15 PM
Rick,
If you are correct, then what would prevent the pump water from exiting through the city water line? Is their a check valve in the city water hose inlet?
John
Ohio
2015 Ford F-350
4WD SRW Diesel
01-28-2014, 06:37 PM
Jack of All Trades
No, as I said, the check valve is integral to the pump. If you look, there have been many posts in the past with people having their tank slowly filling up due to the check valve in the pump failing.
Rick
Edit:
Whoops, I didn't read your question right.
Yes, there is a check valve in the city fill fitting. Again, there have been many posts in the past where, when on the pump, water is shooting out of the city fill. If you pull the screen washer out of the city fill you can see this check valve. Many times when water is coming out of the city fill, pushing on the stem of this check valve will fix the problem.
Rick
01-28-2014, 07:08 PM
Carknocker Family
Did it come equipped with a antifreeze suction line? Mine did not, reading the internet real quick on your TT. I didnt find anything to suggest that it did. Maybe overlooked it, but didnt find anything.
2017 Ram 2500
2014 Salem 32BHDS
01-28-2014, 07:32 PM
Looks to me like RJHuser in post 11 and 13 is correct if you have the installed antifreeze line.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
01-28-2014, 08:03 PM
John
Is the black device near the pump a selector valve, and where does the blue line terminate? If black item is selector valve then, that is the inlet side of pump, one line from potable tank other line goes into anti-freeze jug. Check valve normally installed on pump outlet. Good luck.
Of all the things I've lost in my life the thing I miss the most is my mind!
01-28-2014, 08:11 PM
I believe this is the installed antifreeze line you are referring to.
Ohio
2015 Ford F-350
4WD SRW Diesel
01-28-2014, 08:20 PM
Okay, I believe this is correct. It would allow ALL water to be filtered through the original filter and explains the two way valve used to winterize the unit.
John
Ohio
2015 Ford F-350
4WD SRW Diesel
01-28-2014, 09:21 PM
Ok,you guys will start to know Youroo knows his $hi-.Took all those posts to figure I was right! We have Seminars for this at the (Tadpole Rally)! Youroo!!
01-28-2014, 09:28 PM
I thought it all along, just didn’t want to upset the others.
John
Ohio
2015 Ford F-350
4WD SRW Diesel
