Old 09-12-2015, 07:32 PM   #1
Taranwanderer's Avatar
Plumbing mystery
So here's the dilemma: when I turn on the hot water faucet (kitchen or bathroom,) I get nice scalding hot water. But when I turn on the cold faucet, I get alternating cold and warm, back to cold, back to warm, etc. I've only noticed this when drawing water from the FW tank and using the pump, but not when using city water. The HW bypass appears to be closed. Any ideas?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (18)21 (19)23
2016 Ford Fusion Titanium (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 09-12-2015, 07:46 PM   #2
Plumbing mystery
Have you checked your outside shower. If the faucets are open put the valve at the shower head is closed you can get the water crossing between hot and cold. Not sure why only on the FE tank but could be because the pressure goes up and down with the pump.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 09-12-2015, 07:50 PM   #3
Plain Old Member
Pretty much what I was thinking. Only place I know they can cross is through that or the bypass, which was closed.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 09-12-2015, 07:51 PM   #4
Head Rambler
Sounds like the check valve on the cold water inlet is stuck open. You wouldn't notice it on city water because the pressure stays fairly constant, where it fluctuates when running the pump and allows hot water to back out of the heater.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-15-2015, 08:00 AM   #5
That's the best idea yet. It's definitely not the outside shower...I had my buddy stand outside and turn them both on while I ran the cold faucet in the kitchen...it immediately became warm (ie, both were mixing out there,) and when he shut them both off, it went back to the fluctuating "cold-warm-cold" pattern. Guess I'll have to look at that check valve. Thanks for the ideas, all!
plumbing
