Old 01-24-2014, 09:25 AM   #11
iluvlcy's Avatar
We bought a small stainless pump from north tools, slips into our external 35 gal tank and takes about 10 min to transfer water, we love it, it is 12v.
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 01-24-2014, 10:24 AM   #12
sail2liv's Avatar
I got a 12v marine water pump to transfer water from containers into fresh water tanks....I use the same filter and hose that I hook up to spigot .... that way will catch any stuff from the pump or wherever before it goes into tank.....I carry a battery in the basement that I use for it or the inverter.....good luck
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 01-24-2014, 10:41 AM   #13
sail2liv's Avatar
Just as a followup some federal parks will not let you hook to the community spigot with a hose, but I can run a 50 ft hose from intake side of pump to a can/bucket under the spigot and a 25 ft hose with filter hooked to outlet side of pump.....and not have to lug the cans around.....to fill fresh water tank.....
Old 01-24-2014, 04:08 PM   #14
Originally Posted by Phil_J View Post
Can anyone recommend a portable water pump that could be used to transfer fresh water from an external water tank into the fresh water tank of the TT?
Applying for a seasonal camp site this year and if we happen to get one will need a way to refill the fresh water tank. Usually the water supply source isn't close enough to drag a hose to.
I bought mine at princess auto approx $40. It has external threads on both ends, therefore you need to get a washing machine hose ( internal threads both ends ) to adapt to the inlet side of pump (12 volt). works great!
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 01-24-2014, 09:23 PM   #15
camper1999's Avatar
Originally Posted by rsl View Post
I like that 7 pin to 12 volt outlet adapter. Did you make that or buy it from somewhere?
The 7 connector I got off of Amazon and it has an accessory outlet built in. I just bought a plugAnd connected the pumps wiring to it
Sent from my SPH-L720 using Forest River Forums mobile app
2011 GMC 2500HD Diesel
pump, water, water pump
