Old 02-06-2018, 01:08 PM   #1
Boots49's Avatar
Send a message via Skype™ to Boots49
Possible water heater check valve location
Wmtire, since you brought up Suburban water heaters, is the check valve on the back of the tank on the cold or hot line & is its intended to keep the hot water from going back into the cold line? The reason I am asking is because the Heartland manual said it was on the hot line. Thank you for the help. One other question, if this check valve fails what would be the symptoms?
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
Old 02-06-2018, 01:16 PM   #2
wmtire's Avatar
Uhhh, not sure where I brought up water heaters unless you are referring to the copy and paste links I provided.
I'm going to split your topic off to it's own thread.
Not all water heaters have a check valve. It all depends how the manufacturer plumbed it. Many heaters have a three valve system, which will not have any check valve in it.
Read this entire thread, which may help:
NO (OR LUKEWARM) HOT WATER -Please read first
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 02-06-2018, 01:22 PM   #3
Boots49's Avatar
You are correct, where I picked it up from & since I have read your article, thank you, you have answered my question, because I have a three valve system.
Al & Susanne
Aka: Puss 'n Boots
Old 02-06-2018, 01:26 PM   #4
wmtire's Avatar
Excellent, sounds like you are good to go now.
Old 02-06-2018, 01:35 PM   #5
For others who may not be aware:
There are at least 7 versions of bypass valve arrangements that I am aware of. See page 2 of the attached.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 02-06-2018, 01:39 PM   #6
wmtire's Avatar
Rockfordroo, I was actually just searching for that same diagram from you. You just saved me a bunch of time.
Old 02-06-2018, 01:41 PM   #7
Timing is everything!
