Old 10-17-2015, 09:33 AM   #1
pashooter's Avatar
Possibly dumb fresh water tank question
Recently traded my Flagstaff trailer for a Coachmen Pursuit MH and not sure how this works. The trailer fresh water tank was underneath - below the level of the gravity fill and associated overflow tube. The MH has the tank above the fill - sitting on the floor under the bed in back - and the fill is the same kind of hose connection as the city water hookup. This means you must have a hose (with pressure) to fill the tank. When I look under the bed I see the fill pipe (into the top of the tank), the pipe running to the pump (off the bottom), and a third pipe off the top that I assume is an overflow... though I haven't figured out where that dumps... yet.
So here's my question. I'm used to dumping my chlorine solution into the gravily fill on my trailer to sanitize the system. How do I get that into a system built like this?
Inquiring minds want to know.
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2018: 6
pashooter is offline   Reply With Quote
Old 10-17-2015, 09:36 AM   #2
Pour your solution into the hose you use to fill the tank and then play away.
Pipeman is offline   Reply With Quote
Old 10-17-2015, 09:43 AM   #3
pashooter's Avatar
Interesting, but yeah... I guess that makes sense. Thanks.
fresh water, tank, water, water tank
