Old 10-22-2013, 07:47 PM   #1
Potable water tank filling up
Each time we hook to water source in a camp ground the potable water tank also fills up is there any way to by pass the potable tank. 2012 19 foot minilite forest river
minilite12 is offline   Reply With Quote
Old 10-22-2013, 07:56 PM   #2
trudinator's Avatar
Theres a check valve or flapper valve that prevents this. Looks like yours is not working.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 10-22-2013, 08:10 PM   #3
where would the check valve most likely be located
Old 10-22-2013, 09:10 PM   #4
The check valve in your water pump needs to be replaced.
Old 10-22-2013, 09:13 PM   #5
Ford Idaho's Avatar
Do you have any valves like these?
Old 10-24-2013, 04:14 PM   #6
trudinator's Avatar
My best guess is on or near your pump.
Old 10-25-2013, 06:40 AM   #7
I had the same problem this spring. I took the pump apart and cleaned the check valve. There was a couple of small bits of plastic in it. I put it back together and it still leaked. So I contacted Shurflo and the pump was still in warranty so they send me a new pump head. I installed it and no more problems! If your pump is relatively easy to access the repair is very simple.
Bruce
'12 Avenger 26BH
'01 Ford Excursion V10 4x4
bwbarnes is offline   Reply With Quote
tank, water, water tank
