Old 05-13-2016, 03:18 PM   #11
Hose diameter
We've used both 1/2 inch and 5/8 inch supply hoses on 4 different TT's/5th wheels. We see no difference in pressure. And you better not turn on another hot or cold water faucet while I'm in the shower, or you will hear about it loud and clear.
Sue, Dennis and Lola
2016 Cedar Creek 38CK
2016 RAM 3500
Kayak30336 is offline   Reply With Quote
Old 05-13-2016, 11:57 PM   #12
Dabmeb's Avatar
1/2 in or 5/8, i carry them both but it realy doesnt make much difference when the campground has low water pressure or only a 1/2 inch line coming out ot the ground to the connection.
Dabmeb is offline   Reply With Quote
Old 05-14-2016, 05:14 AM   #13
If your RV has a "Winterizing Valve" like this it would make NO difference if the supply line was a Fire Hose,you are still Reduced at this valve! You can see for yourself the "Opening" is Less than 3/16 of a Inch! Youroo!! The large Drill bit is the PEX ID size,the small drill bit is the Valve opening size,the flow size through the Valve is 1/2 the size of the Small drill bit!
ID:	107805   Click image for larger version
ID:	107806   Click image for larger version
