Old 05-12-2016, 08:16 PM   #1
WFD
Potable water hose 1/2 in or 5/8???
Currently have 5/8 inch potable water hose. Want to get better quality but notice there is a ton of 1/2 inch out there, and 5/8 to a lesser degree...will I notice a difference? Should I stick to 5/8 inch?
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 05-12-2016, 10:21 PM   #2
I don't think you will. I have never seen anything bigger than 1/2 lines in a TT. If you had a big FW running the washer and taking a shower might be an issue...
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 05-12-2016, 10:41 PM   #3
dea49's Avatar
Used a 5/8 for the 1st time on last trip. Didn't notice any difference until I ran the outside shower while DW was using kitchen sink. The water flow drop was far less noticable.
dea49 is offline   Reply With Quote
Old 05-13-2016, 07:30 AM   #4
Head Rambler
You won't notice much difference if any. All the outlets in an RV have restricted flow devices in them so ˝" hose is more than enough to run a couple at a time. You'll have more restriction through a regular pressure regulator than the hose.
Gotta go campin!
Old 05-13-2016, 07:38 AM   #5
This is the corner I am in also! Youroo!!
Old 05-13-2016, 07:49 AM   #6
bubbles's Avatar
I'm in the larger diameter hose corner. I think it has been said "it's the volume that does the work" and therefore 5/8 is my choice and what I use.
Old 05-13-2016, 10:31 AM   #7
jeff64's Avatar
Check this one out Valterra W01-7300 White 5/8" x 25' Kink Free Drinking Water Hose(Amazon...where else). I've had a pair of these for a few years. They wind up quite compactly on what you would use for and extension cord. Getting a decent/ durable hose that stores well isn't the easiest thing to find. I've used those hoses that look like an imitation firehose( they're junk) IMHO. This one gets two thumbs up in my experience
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-13-2016, 11:37 AM   #8
X 2
2015 GMC Denali 3500 4X4 Duramax
2015 Cedar Creek 36CKTS (flooded 2-20-18)
2019 Cedar Creek 36CK2 (picked up 5-1-18)
grumpyoldman is offline   Reply With Quote
Old 05-13-2016, 11:55 AM   #9
Canadian Member
The PEX in your unit is 1/2" so the larger hose still feeds into the smaller diameter water lines before it gets to any faucets.
2019 Rockwood Signature 8290BS
Old 05-13-2016, 12:02 PM   #10
True.
And as long as you only used one faucet, the larger supply hose would not make a difference.
It's when you open two or more faucets that the larger supply line helps and then, really only on the cold side as the 1/2" pex is usually pretty short from the city hook-up before it branches out to the various plumbing runs.
Of course, all this depends on at least 5/8" diameter (or >) supply at the pedestal/water bib.
EDIT: Pressure (for me) is WAY more important than supply hose diameter.
Days Camped: '16=46 '17=30 '18=51 '19=36
water
