Old 01-22-2017, 03:22 PM   #1
Kanadian Kamper
kenandterry's Avatar
Power flush a grey tank?
My Georgetown has a factory equipped black water tank flush connection for a garden hose to power wash the inside of the tank. It helps keep things clean and helps with the accuracy of the indicator panel inside.
Anyone got a similar solution for the grey water tank? I'm not aware of any factory equipped units for any make or model of RV. Not sure why the manufacturers don't provide one.
Ken and Terry
kenandterry is offline   Reply With Quote
Old 01-29-2017, 11:16 PM   #2
You can install a power flush or make a setup. Run hose down vent pipe, just make sure you open the drain valve. If tank is full it creates enough suction to clean out tank during draining.
mfMcFroggierPod is offline   Reply With Quote
power, tank
