Clogged Pre Filter on Water Pump
Just got back from a short 2 day trip and was having problems with the water pressure. We also left the pump on for a least 30min with no water in the tank on the way home. Pump was dry and running when I parked the trailer. Filled up the tank, pump was running and no pressure. So I started researching new water pumps and figured I wanted a good variable speed pump to help with vibration and pulsating water issues.But decided before I buy that new $175 pump I should check the basics, loose fittings, clogged filter etc. This is what I found in the pre filter connected directly to the water pump.Yuk! Pretty disgusting stuff.Anyway, thought I would share, lesson learned- check those water filters.
(I also have a small issue with algae in the fresh water tank that the bleach solution obviously didn't fully take care of. gonna be doing that again here real soon.)
2018 Toyota Tundra Crewmax
2017 Mini Lite 2509S
2012 Mini Lite 2306, 2000 Storm 32ft Class A w/dbl slides, 1998 Class C 23ft Fleetwood, 1990 8ft Lance.
Nights Camped 2016- 15, 2017- 30,2018-27, 2019-36 2020-21
