Old 05-11-2015, 08:25 PM   #1
Pressure in water lines when pump is off
Ok, our toilet was leaking only when we flushed it so my husband replaced the vacuum breaker. Now it works great. One thing that surprised him was that when he removed the water lines to take the toilet out, water was spraying everywhere like the lines were pressurized even though the water pump was not on. Why would it do this?
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 05-11-2015, 08:30 PM   #2
bubbles's Avatar
If you didn't open a cold water faucet or flush the toilet to relieve the pressure in the lines you see the results. All the water lines once pressurized will retain that pressure until opening a faucet, opening low point drain or such. Just like at home.
Old 05-11-2015, 08:31 PM   #3
Just residual pressure. He should have released the pressure on the line by flushing it or turning on both faucets in the lavatory.
Old 05-11-2015, 08:35 PM   #4
Thanks! This is our first TT so everything is new to us. We have not camped in it yet but getting it ready to camp for the first time the end of the month. We bought it in January so we were not able to test out the plumbing system until recently and found out the toilet leaked. We are glad it was an easy fix.
2011 MicroLite 23LB
Old 05-11-2015, 08:35 PM   #5
Flybob's Avatar
That's why you are supposed to relieve pressure on system before removing WH drain plug or anode rod. If you don't it will be the plug and water that will shoot out.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-12-2015, 01:10 PM   #6
BooBoo23's Avatar
One of the first things I learned about RV's and won't forget it. Fortunately the water was not hot.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 05-12-2015, 01:27 PM   #7
ColoradoRick's Avatar
lol...yep residual pressure....getting soaked from opening the water tank drain plug was my first lesson!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 05-12-2015, 01:32 PM   #8
X2
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 05-12-2015, 06:31 PM   #9
The plastic (PEX) water tubing is flexible. It expands a little under pressure, so it holds pressure.
Also, if the water in the water heater is cold and if no faucet is opened or if the toilet is not flushed as it heats up, as the water expands it will build pressure in the system. Since the cold and hot lines are all connected, it pressurizes everything. That's why the water heater relief valve sometimes drips.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
pressure, pump, water
