Old 03-03-2010, 11:41 PM   #1
Pressure Reducer on Water System
I thought I saw somewhere that I should put a reducer on the water supply when I'm tapped into the campground's supply. What pressure should I target? Is there a specific reducing fitting I should be looking at?
Cougguy is offline   Reply With Quote
Old 03-03-2010, 11:51 PM   #2
It's a pressure regulator, and most are set for 40 psi. These can be found at camper supply stores, and maybe even Wal Mart. Some campgrounds run a high pressure due to demand of many campers. Most trailers should not have much over 40 psi inlet water pressure. Get the brass one and not the plastic. I have read several post where the adjustable one with the gauge doesn't work correctly.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 03-03-2010, 11:58 PM   #3
piscesman's Avatar
Yup...anything over 45 psi (pounds per square inch) and you risk blowing something out. Most basic ones are preset...some come with a gauge. Some are adjustable but you'll pay twice as much. Any RV store will carry them...and a few hardware stores. Be sure to put it directly on the campground tap or you may blow out your supply hose.
2003 GEORGETOWN 325
"NOT ALL WHO WANDER ARE LOST"
Nights camped in 2011: 108
Nights camped in 2012: 41
piscesman is offline   Reply With Quote
Old 03-04-2010, 12:01 AM   #4
NWJeeper's Avatar
I used to use one on our last rig but on the Georgetown I notice very poor pressure if I use a regulator. I think this is because the factory installed water filter serves to cut down on the pressure. Have largely stopped using one. I do make it a habit to turn off the water supply when we are away from the rig though.
Ed & Wendy
www.nwjeepn.com
Old 03-04-2010, 01:46 AM   #5
That's exactly what I do. Had same problem- especially low pressure when taking showers. Have the regulator in the rig, just in case, but also turn off water when we leave it sit.
MightyMike is offline   Reply With Quote
