04-16-2018, 07:11 PM
#21
Originally Posted by rockfordroo
You're doomed! DOOMED!!
Have been for 70 years.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
04-16-2018, 08:53 PM
#22
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Larry,,,,the toilet seal IS good,,,,,and it would have shortly been coming out of the roof vent,,,,but she opened the toilet valve and that's when it hit the fan.
04-16-2018, 10:23 PM
#23
My orange black flush hose has it's own regulator. This after I let the full pressure go into the black tank flush port once. Afterwards I had water dripping from the pack flow preventer area under the bath sink. I'm thinking all the plumbing is the same type so it all needs to be protected
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
04-17-2018, 06:41 AM
#24
Originally Posted by DrLewie
The instruction manual with my flusher said not to use a pressure regulator at all...use full city pressure. Also, I read an article somewhere in the past cautioning about possible backflow from the black water tank, through the flusher into the hose and possibly causing contamination. I don't know if it's true, but I use a different hose for the flusher and don't use the regulator with the tank flusher.
I added a backflow preventer to my Y as a precaution in case of backflow.
04-17-2018, 07:06 AM
#25
And you wonder why you never grew to be taller than 4’-6”.
Bruce
04-17-2018, 07:21 AM
#26
Originally Posted by sut001
I was always told to use white hose only for potable water. (drinking water) Use a 2nd hose for black tank--washing rv or whatever. They now sell a blue hose for potable water. Standard hoses may give off a chemical. While growing up we always drank from hoses.
For years, I've used a white hose for city water, and a blue one for flushing my black water tank. They were both labeled for potable water when I bought them, but it's easy to tell which one I'm using for my black water tank cleaning [emoji16]
04-17-2018, 08:31 AM
#27
I see no reason for a pressure regulator for flushing as it will never be holding pressure like the inside plumbing
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
04-17-2018, 08:54 AM
#28
Exactly!!! Unless you forget to stop filling the tank like was mentioned by someone else.[emoji16]
04-17-2018, 09:11 AM
#29
But a pressure regulator won't solve this dilemma.
04-17-2018, 09:14 AM
#30
Well said!
04-17-2018, 09:16 AM
#31
Well said!
I'm sorry to say I know too much about this!
04-17-2018, 09:23 AM
#32
My bh's job is to keep an eye on the level and knock on the wall to get my attention. That seems to work most of the time, but we've had a close call now and then. I used to time how long it took to fill the bw tank. That generally seemed to work. But different cgs have different pressures so she always was a helper.
04-17-2018, 09:36 AM
#33
Or was it "she opened the toilet valve and that's when it hit the fanny".
We love camping in our Shockwave!
2016 t28FQDX Shockwave,
New Provider tires 10/31/18 ,
2021 Chev LT 3500
2020 Polaris RZR 900 Fox Edition
04-17-2018, 10:09 AM
#34
Location: Alberta - East of the Rockies, West of the Rest
I have never used a pressure regulator when flushing the black tank, it simply restricts the flow to much.
To keep an eye on the amount of water pumped into the tank I bought this about a year ago and really like it better than using the stopwatch on my phone.
https://www.amazon.ca/RAINWAVE-RW-9F...ds=water+meter
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
04-17-2018, 10:19 AM
#35
I gotta get me one of those! [emoji16]
04-17-2018, 10:21 AM
#36
I bought two a couple years ago!
One to use when flushing the black tank.
Another to use when adding/filling the fresh water tank.
They work well.
04-17-2018, 10:28 AM
#37
Denver To Yuma In 90 Days
I ordered one of those from Walmart.com ($16) a couple of months ago for pickup in the local store.
I've used it on my fresh water tank, but haven't on my flush valve.
As for using a regulator on the flush...nope!
04-17-2018, 11:07 AM
#38
Not at Walmart anymore. Ebay for $17 something-free shipping
04-17-2018, 11:23 AM
#39
From working in Industrial Waste Management for years the first thought that comes to my mind in regards to using a water hose for black tank flushing is: I would not use a water hose to feed water to a black tank flush unless I also had a Back Flow Prevention Valve (BPV), sometimes called a Back Flow Prevention Device (BPD) valve installed. There is a chance that while using a water hose connected to the black tank flush connector on you RV, TT, 5-er, that the water supply could drop pressure. Another IF: If your hose that goes into the black tank goes in so as to be below the water level at any point and the supply water pressure drops they you would have a siphoning effect which could draw water from the black tank into the water supply piping causing contamination. The BPD's can be found small that would work carrying it with you in an RV and don't cost that much. My opinion on the regulator: For black tank flushing I would not want to regulate the water pressure. I would want as much pressure and volume as I could get. Just my 2 cents
04-17-2018, 11:28 AM
#40
I know it didn't come from Walmart, but was ordered on the Walmart website and delivered to my local (at the time) Walmart store!
Free delivery to the store...$6 shipping to my door!
Probably cost me $1 in gas to go pick it up...plus I got some needed groceries while I was there.
To me that was a no brainer!
