Old 06-11-2015, 11:58 AM   #1
Pressure regulator for 120 PSI
I have two of the small inline pressure regulators. However they appear to be worthless when the water pressure is 120 psi.
My house is on a regulator down to around 35 psi. But the house we bought recently has 120 psi at the full hookup RV pad.
I could run a bunch of extra hoses to connect to the house instead, but I would have to drive over the hose driving to the rear garage.
I do not want to jack hammer the walkway apart so I can run a new water line.
I would prefer something that is smaller than the regulator that is on the house.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
PopBeavers is offline   Reply With Quote
Old 06-11-2015, 12:07 PM   #2
Just buy a Watts adjustable water pressure reg. an set it at your desired pressure! Youroo!!
Old 06-11-2015, 04:31 PM   #3
I can see that this would work well at home by just putting in on my RV water supply line.
It looks a little bulky and awkward to use on the road.
Old 06-11-2015, 04:34 PM   #4
Mount it inside the unit behind the wall on the inlet hose.
Old 06-11-2015, 04:39 PM   #5
fonzie's Avatar
made just for rv's, not bulky and ackward
LFH560 Lead Free* Mini Brass Water Pressure Regulators with Hose Connections, Water Pressure Reducing Valves - Small Capacity, Water Safety & Flow Control - Watts
Fonzie
Old 06-12-2015, 01:44 PM   #6
Valterra offers an adjustable regulator with built in gauge for RV's.
edcronin01 is offline   Reply With Quote
Old 06-13-2015, 01:06 AM   #7
125 psi water pressure
Is it feisable to fill the fresh water tank and use the 12v pump for water supply
Big Bill is offline   Reply With Quote
Old 06-13-2015, 04:18 AM   #8
Witch Doctor's Avatar
Yes no problem at all.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 06-13-2015, 04:59 AM   #9
Herk7769's Avatar
I broke mine
DO NOT hold the dial in your hand while tightening the connections.
HAM CALLSIGN - KC3FFW
Old 06-13-2015, 06:47 AM   #10
Regardless (Which/What) Regulator you use when the (Supply PSI is 120) the Regulator must be placed at the Source! 99% of the White water hoses RVers use will look like a (Anoconda that has eaten a litter of pigs)! Youroo!!
pressure
