Old 01-16-2014, 10:52 AM   #1
Whim Travler
Pressure when Hot water is on
Have a Sabre Palimino, 5th wheel, 2012. This year in campground, when we turn on the electric to the water heater and it gets hot, pressure is built up in the the system and leaks at the cold water pipe running into the toilet. Not sure why. Is there something we need to be doing to drain the pressure from the hot water heater when parked long term?
Dianizon
dianizon is offline   Reply With Quote
Old 01-16-2014, 10:59 AM   #2
Ford Idaho's Avatar
Is the water heater pressure relief valve working?
Turn off the water heater.
Test it by carefully (hot water is hot)flipping the stem up, does water come out does the stem move easy
Are you using a water pressure regulator?
What is the water pressure at the spigot?
Old 01-16-2014, 11:47 AM   #3
Professional Curmudgeon
wrvond's Avatar
The hot water lines and the cold water lines are separate before the water heater. The only common connection points are at the city water connection and the water pump. The water heater's electric element should have no more effect on water pressure than the gas water heater circuit. Unless the switch is incorrectly wired and you are actually turning on the water pump. Even then, the system should not be pressurized to the point it leaks inside. Your leak is probably nothing more than a loose connection that needs repair.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 01-16-2014, 12:06 PM   #4
TURBS's Avatar
I concur.
TURBS
golf cart safety instructor
hot water, pressure, water
