Old 11-03-2013, 09:36 AM   #11
Originally Posted by DDC View Post
Sure sounds like the vent pipe is too far down in the tank, by taking the cap off of the black tank rinse you allowed more air in which points to the vent pipe being the problem.
Tank rinser has a backflow valve(spring loaded) unles broken (Air/Fluid) can not return to outside. Pressure req.to open valve. Youroo!! Vent tube is (Below) liquid level!
Old 11-03-2013, 10:19 AM   #12
DDC
DDC's Avatar
It can if it's sucking from in the tank, it would be sucking air in not out.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 11-03-2013, 11:01 AM   #13
Still say he needs to measure down to tank bottom and the vent tube from the roof as stated in post #3.
Old 11-03-2013, 11:47 AM   #14
DDC
DDC's Avatar
X2
Old 11-03-2013, 11:53 AM   #15
DAISY BOYKIN's Avatar
Vent fan may be on ?????
If your vent fan is on and you do not have a window slightly open the fan will draw air through your "JOHN" when flushed. The fan will pull air down through the tank vent!!!!!!!!!!!!!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is online now   Reply With Quote
Old 11-03-2013, 12:16 PM   #16
Originally Posted by herk7769 View Post
If the vent starts filling after only a few minutes, the pipe may have been installed too low in the tank.
Could just fill the black tank with water. Open the black dump valve and listen for the vent on the roof to start sucking air. If the vent in the tank is above liquid level, as I guess it should be if correctly installed, it should start sucking air immediately after opening the dump valve.
Same thing as sucking the water out of the sink traps when emptying the gray tank.
I bet his tank empties slowly too...
Hudlow is offline   Reply With Quote
Old 11-03-2013, 12:29 PM   #17
Ford Idaho's Avatar
I am starting to wonder if someone/anyone told OP how to drain the tank.
Old 11-03-2013, 04:40 PM   #18
Meaning what?
cdnwillyg is offline   Reply With Quote
Old 11-03-2013, 04:46 PM   #19
Ford Idaho's Avatar
Originally Posted by cdnwillyg View Post
Meaning what?
Over filled tank plugged/blocked the vent tube.
Old 11-03-2013, 04:56 PM   #20
Director, FROG
F.R.O.G.'s Avatar
That's where I was going with the question about when the tank was last dumped.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
black, black tank, pressure, tank
