Old 05-25-2014, 10:19 AM   #1
billster_ny's Avatar
Prime Time Tracer electric hot water not working
I have a new 2014 Tracer and the electric hot water doesn't work. I filled with water and turned on the Atwood switch in the bathroom. The light between the electric and gas doesn't illuminate. I left the switch on for an entire day, no hot water. Used the gas and that works great. Is there another switch to turn on the water heater and where is it?Click image for larger version
Name:	ImageUploadedByForest River Forums1401031155.409935.jpg
billster_ny is offline   Reply With Quote
Old 05-25-2014, 10:33 AM   #2
wmtire's Avatar
Just to make sure, but you must be plugged into a form of 120 volt shore power for the electric side to work. The propane side will work off batteries but not the electric side.
Look on the backside of the water heater, for another main switch to turn on, and also to be sure the water heater is plugged into an outlet (which sometimes get's forgotten at the factory).
Also check your RV's breakers to make sure the water heater electrical circuit is flipped on.
Hope you find the problem.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 05-25-2014, 10:34 AM   #3
Professional Texan
TexasBob's Avatar
Originally Posted by billster_ny View Post
I have a new 2014 Tracer and the electric hot water doesn't work. I filled with water and turned on the Atwood switch in the bathroom. The light between the electric and gas doesn't illuminate. I left the switch on for an entire day, no hot water. Used the gas and that works great. Is there another switch to turn on the water heater and where is it?Attachment 53259
Did you check your breakers?
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 05-25-2014, 10:47 AM   #4
Did you have Both switchs turned On? Gas & Elec. Youroo!!
Old 05-25-2014, 10:57 AM   #5
Todouble's Avatar
I have a 14 prime time unit that has both switches like pic above. Mine works on gas and elec but I can tell you that I've never seen that light come on. I Don't think it is suppose too.
Todouble is offline   Reply With Quote
Old 05-25-2014, 12:32 PM   #6
heavynlori's Avatar
The light only comes on when using gas option - and it will only come briefly as it lights
heavynlori is online now   Reply With Quote
Old 05-25-2014, 06:14 PM   #7
Breakers are good.
Old 05-25-2014, 06:33 PM   #8
We have a 2015 255 air and were having the same problem till I've noticed that only one of the valves that go out of my hot water tank was on and the other had a bypass was still in place.
Sent from my IdeaTab S6000-F using Forest River Forums mobile app
tracer 255 is offline   Reply With Quote
Old 05-25-2014, 06:34 PM   #9
Where are the valves at?
Old 05-25-2014, 06:36 PM   #10
But to have hot water you have too have both on gas and electric. This new water heater doesn't have a tempature set gage like my old Wildwood had
electric, hot water, prime time, water
