Old 11-19-2014, 10:13 AM   #1
Primetime Tracer 3200 BHT
Hello all, new to the forum. I had a little trouble figuring out how to post? I'm technilogically Challenged. I'm sure this has already been asked, but, can someone tell me how to access my water pump? It didn't work from the beginning and it almost a year old? Fortunately, we normally camp where there is water. But, I will need it next month. Any help is greatly appreciated. Thanks in advance!!!
ras308 is offline   Reply With Quote
Old 11-19-2014, 11:59 AM   #2
On my Tracer 2600 RLS it is behind a panel under the kitchen sink.
Baddison is offline   Reply With Quote
Old 11-19-2014, 12:02 PM   #3
Pump
I think mine is beside the bed, but I don't see an access panel? I called the service department from where I bought it, he said it's hid very well. So I will check it this evening.
Old 11-19-2014, 02:39 PM   #4
Dave_Monica's Avatar
It should be near the city water connection on your camper behind a removable panel. Look for a in-line fuse on the power supply to the pump and check.
Dave
Old 11-19-2014, 02:45 PM   #5
It runs
It runs, just doesn't pump. Hopefully I just didn't look close enough and there's a removal panel beside the bed?
Old 11-19-2014, 02:53 PM   #6
On your Tracer, is there a selector switch to choose, pump, city water etc.?
Dave
Old 11-20-2014, 08:58 PM   #7
The pump is in the rear bedroom. As you walk in the panel on the left right at the ladder. Under the shelves. Remove four screws from 2 foot by 2 foot panel. No where near city water hook up
mlineman55 is offline   Reply With Quote
Old 11-20-2014, 09:03 PM   #8
These units come with a winterizing kit installed from the factory. That provides a few valves and hoses. Make sure it is set to pull from the fresh water tank and not the pink fluid hose. Also make sure the suction screen is clear of debris
Old 11-24-2014, 09:54 AM   #9
Strange location
That seems like an awful strange place to put it??? But, it does explain why I haven't found it. I'll check it out. Thank you!!!
Old 11-24-2014, 11:48 AM   #10
TomStacey616's Avatar
DITTO, what he said... i've got the same model as well!!
2010 Tundra DC SR5 TRD 5.7L towpkg (gone)
2008 F350 Lariat CC DRW 6.4PSD
2013 PT Tracer 3200BHT
BlueOX SwayPro (used when hauling cart too)
TomStacey616 is offline   Reply With Quote
