Old 08-28-2012, 08:43 PM   #1
CampingQueen
Probably a stupid winterizing question
Thinking ahead to colder weather here...and hoping this is not a stupid question.
I live in NC, where we have some cold nights during winter, but not bitterly cold for a hours at a time, generally.
Winterizing with antifreeze, makes perfect sense if we were poing to park the camper all winter, however we are planning on using the TT periodically throughout the winter (probably a trip every 4-6 weeks or so). Does that still make sense to winterize? Wouldn't we have to un-antifreeze and then re-antifreeze after every trip?
We had a popup last winter (Highwall with a 'real' toilet and grey/black/fresh tanks) and just kept the fresh water tank empty and had no problem, but it was a mild winter with very few nights below freezing.
This year we have the 30 ft V-lite...
Are there other alternatives to winterizing with antifreeze if we plan on using the camper periodically throughout the winter?
It does have the tank heaters for the grey/black/fresh tanks.
What if we just turned on the propane heat in the camper (or used a large AC electric space heater to keep the inside temp above freezing) and the tank heaters for any bitterly cold days/nights where it was calling for temps to stay below freezing for more than a few hours? In our typical winter, that's not too many nights.
Am I missing something obvious? I sure don't want to make a wrong decision and end up with freeze damaged plumbing!
arlee453 is offline   Reply With Quote
Old 08-28-2012, 09:04 PM   #2
TURBS's Avatar
How about just blowing your lines out with compressed air and draining low point drains after each use.
And of course the Hw heater.
Pretty simple and fast.
Then just dump some rv antifreeze in traps
Old 08-28-2012, 09:12 PM   #3
Road-King's Avatar
X2 f1100turbo said...
I live in TN, so close to the same winters. I use a air hose quick connect from harbor tools, a old garden hose with a good male end and a heater hose clamp. Drain the hot water heater. Drain ALL tanks including the built in water filter(I'm going to by-pass that). Open all water valves. Then I hook my air compressor up to the city water inlet an blow about 25 psi through the system. Close one water valve at a time. When there is no more water coming out the low water drains I cut the air then close them. Put enough antifreeze in all drains to fill the traps (about 1 gal). Never had a problem...
Easy to un-winterize, just hook up the water, drain all the air out of the hot water heater and the lines and I'm back in business...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-28-2012, 09:54 PM   #4
jtstromsburg's Avatar
Yup, what they said. I live in Nebraska and it gets plenty cold here. Last Winter, I fully winterized but left a oil filled heater going in the trailer with cabinet doors open and a remote thermometer inside the camper. Never got below 40 & I didn't notice much difference on my utility bills.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 08-29-2012, 08:08 AM   #5
CampingQueen
OK, so I'm not crazy... thanks for the tip!
When we did the walkthrough the tech was talking about winterizing using the port & antifreeze. I asked this question - would it just be OK to drain everything really well, and then blow some low-pressure air through the lines with the spigots open to get the water out of the system (which is basically what we did on the popup) and he was not keen on the idea, insisting that we needed to fill the system with antifreeze.
My original thinking was that draining out all the water really well so it wouldn't freeze and burst a pipe would be just as good as using antifreeze, but then after what the tech said, I thought maybe there was more to it that I just was missing (like you need to always keep fluid in the system for some reason I couldn't fathom). Maybe he just wanted to keep the antifreeze people in business?? Or it's a factory training thing?
Anyhoo, thanks for the advice. I think we will go the blow-out route!
Old 08-29-2012, 08:18 AM   #6
TURBS's Avatar
Yes blowing the system out with air is commen practice just as antifreeze.
I inject antifreeze just because it's WHAT I do.
I enjoy doing maintenance in and around my camper so I don't mind if it takes longer or not .
Good luck and have fun !
Don't forget to get into the photo contest !
Old 08-29-2012, 08:57 AM   #7
Install a winterization kit, which allows you to quickly winterize and of course, dewinterizing is a quick, simple process. We face a similar situation here in Colorado, where our first hard freeze arrives in mid-September.
rmdrifter is offline   Reply With Quote
Old 08-29-2012, 10:02 PM   #8
Briorick's Avatar
I too am new to the winterization aspect. Are the kits all standard fitting, one size fits all? And any suggestions. I have an 09' Fr Rockwood Freedom Ltd 1940 Pop Up. Thanks!
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 08-30-2012, 08:11 AM   #9
Don't know about your TT specifically, but all the ones I've seen the plumbing has been set up the same with few variations. You intercept the fresh water line going into the pump, install the kit, which allows you to pump antifreeze instead of water into the lines and the pump. All other details regarding winterization/dewinterzation are well-documented and discussed on this website. Here is an example of the kit: Camco 36543 RV Pump Converter Winterizing Kit : Amazon.com : Automotive.
Old 08-30-2012, 08:40 AM   #10
Witch Doctor's Avatar
I live in Southern Virginia, right above the NC boarder in Clarksville. I have never went through the process and I did not have tank heaters except on my newest RV. I have lived here for 10 years. All I do is leave a little electric heater going inside the unit set at about 60 degrees. I have never had a problem. With saying that I do empty my tanks. Maybe I have just been lucky. The heater really only runs a lot on cloudy day's, other then that the good old sun will heat the inside. We normally only drop down below 32 for a few hours in the early morning. There are not many day's that we stay that low for a long period of time........
