Old 04-13-2014, 11:00 AM   #1
Lawson's Avatar
problem with hose
We recently purchased a 2014 Salem 241 QBXL. Yesterday we hooked up our water for the first time. There is an unconnected hose in under the bedroom that has a valve. When the camper was connected to the city water, the water flowed out of the unconnected hoses. Used a hose clamp to connect the 2 ends, however the hoses were pinched. Any suggestions on how I can resolve this? Also can anyone tell me why there is a valved hose in under the bedroom when there is not a sink or water spickett in that area of the camper? Thank you
Lawson is offline   Reply With Quote
Old 04-13-2014, 11:03 AM   #2
Ford Idaho's Avatar
Is there a water filter in a drawer someplace?
Old 04-13-2014, 11:06 AM   #3
Lawson's Avatar
Hoses are not long enough to connect to a water filter.
Old 04-13-2014, 11:11 AM   #4
Ford Idaho's Avatar
Ah, would it be possible for you to post a picture of this situation ?
Old 04-13-2014, 11:14 AM   #5
Lawson's Avatar
Not until next weekend. Thanks for your help tho
Old 04-13-2014, 11:16 AM   #6
Oakman's Avatar
Are these hoses you are talking about inside the camper or outside under the camper?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-13-2014, 11:31 AM   #7
Lawson's Avatar
Two unconnected white hoses come from the inside of the bottom of the camper to the outside. One of the hoses has a valve on it.
Old 04-13-2014, 11:34 AM   #8
Ford Idaho's Avatar
AHHH the one with the valve is a low point drain and the other is a fresh water overfill drain.
I miss understood your first post my apologies.
Old 04-13-2014, 11:47 AM   #9
Lawson's Avatar
That makes sense, but when it was hooked to city water, the water continuously came out of the over flow hose.
Old 04-13-2014, 12:07 PM   #10
Ford Idaho's Avatar
Is there a valve that needs to be turned in the docking station?
City to tank.
Old 04-13-2014, 12:23 PM   #11
Boss Ox & Drovergirl
oxcamper's Avatar
Low point drain has the valve, the other hose is the fresh water oerflow.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 04-13-2014, 12:59 PM   #12
Brother Les's Avatar
Are you sure that you are hooked up to the city fill? You may be hooked up to the Fresh water tank and water is coming out of the fresh water tank drain or over flow.
If you are hooked up to the true city fill (I have two hose fills, one for city and one for the freshwater on board tank), your water pump back flow prevent er may not be working.
Brother Les
