Old 07-09-2014, 08:14 PM   #1
Super Thirty's Avatar
Problems with water pump?
I have a 2014 Shasta Oasis. Filled the fresh water tank until water ran out. Gauge indicates full. Water pump works until about 8 to 10 gallons used and then pump stays running. Thought tank was empty so I filled. It didn't take long to full so I emptied the tanks and there was about 12 to 15 gallons in the tote. When I filled the pump quit running. It has now done the same thing the second time. Any suggestions what might be the problem?
Super Thirty is offline   Reply With Quote
Old 07-09-2014, 08:29 PM   #2
Wonder if the pickup tube for the water pump is not Installed in the tank enough.
clutchd is offline   Reply With Quote
Old 07-09-2014, 08:41 PM   #3
Can u determine that without dropping the tank?
Old 07-10-2014, 04:55 AM   #4
Herk7769's Avatar
Levelness and discharge port location will determine how much "unusable" water is left in the fresh tank.
This is my 5th wheel tank and (even though almost level) you can see the fill tube will stop filling and the tank indicator will only read 2/3 full (yet it will not take additional water without bulging the tank).
The good news is that in this position a good portion of the water "is usable."
Tilted the opposite way, the top of the water outlet will suck air while a good amount of the water will be "unusable." However with this tilt, the tank can be completely filled.
Name:	Horst Probe Install 020.jpg
ID:	57790   Click image for larger version
Name:	Horst Probe Install 019.jpg
HAM CALLSIGN - KC3FFW
Old 07-10-2014, 12:05 PM   #5
We have a surveyor cadet and if yours is like ours the outlet to the pump was way too high. We could only use a little over half the tank. I capped off the original outlet, then integrated it with the drain on the bottom and we can use every last drop now.
climbbike is offline   Reply With Quote
Old 07-11-2014, 08:13 AM   #6
Thanks for the info. Gives me something to look for.
Old 07-19-2014, 01:51 PM   #7
LouNick's Avatar
Simple yet clever modification. I like that!
Lou and Paula
2014 Rockwood 8289WS UltraLite w/Revolution Pinbox Engaged.
2011 F250 Power Stroke Super Duty King Ranch Super Crew Cab w/Reese 16K Hitch
Lou & Paula
2014 Rockwood 8289WS Ultra Lite w/Reese Revloution Pinbox.
2011 F250 Power Stroke Super Duty King Ranch Super Crew w/Reese 16k Fixed Hitch
LouNick is offline   Reply With Quote
Old 09-22-2014, 02:04 PM   #8
Hi I do not travel with my TT. I only use the water pump to winterize.I have a 2011 Surveyor Select 264. There is a small constant drip from the pump. I keep a dish under it and empty the water leaking. Where is the water coming from I do not use the Fresh Water Tank I use city water and have a water regulator attached to hose.
niclab is offline   Reply With Quote
Old 09-22-2014, 02:39 PM   #9
Ford Idaho's Avatar
Is your city and FW tank different connections or the same?
Old 09-22-2014, 03:12 PM   #10
Engineer of Crazy Train
ChooChooMan74's Avatar
Your line from the pump is pressurized from the city water inlet and is stopped from entering the tank by a one way valve. If you don't use the tank, disconnect the pump and plug the pipe.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
pump, water, water pump
