Old 01-16-2012, 03:37 PM   #1
wfmdfm's Avatar
Propane Issues
I have had several occasions where I am switching between a empty or almost empty tank and then my systems will not run. We have a 2011 Flagstaff 8528RKWS. I wanted to heat up the camper today to work on my sound system rebuild. It is a cold New England day around 15 to 20 outside. The heater would not turn on. After tapping on the tank and looking at the indicator on the transfer switch it was RED. So I switched tanks gave the other tank a tap and could tell it was full. The indicator was still red and the heater would not run. I turned off the heater and the indicator turned green. I lit the stove the indicator went red and the stove flame went down. After messing with it I figured that there must be a issue with the full tank so I refilled the empty and put it in place. Indicator was green. The stove lit and burned for a bit so I started the heat. It lit but the indicator never turned red. As soon as I shut off the heat it turns green. I am still covered for another 15 months and figure I will bring it back to the dealer but thought I would run it buy the forum and see if I am missing something simple.
Wally
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 01-16-2012, 04:23 PM   #2
papap's Avatar
Sounds like a bad regulator or maybe the bottles are over filled. But I would bet bad regulator.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 01-16-2012, 04:24 PM   #3
MtnGuy's Avatar
There are some built in safety precautions with the propane system so that it will not (or should not) allow gas to escape at a high rate in case of a line failure. Make sure that all gas appliances are off before slowing turning on a tank. If there is not pressure on the line, there is a safety mechanism that will limit flow.
Read about the "flow limiting device" about 2/3s of the way down the page here: http://www.motleyrvrepair.com/propan...ty_and_use.htm
Old 01-16-2012, 06:29 PM   #4
Lottery Non-Winner
Ovair's Avatar
X2 on opening the tank slowly. I'm sure I'm safer with the new LP tanks, but I prefer the old ones. Less hassle.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 01-16-2012, 06:29 PM   #5
sherdep's Avatar
I had to replace one of the hoses from the tank to the regulator cause it caused something similar to what you describe.
the hose is called - Propane Acme Flexible Pigtail Hoses
Its about a $15 part - by far cheaper then the gas it costs in taking it to the dealer to have it fixed under warranty
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 01-16-2012, 07:39 PM   #6
onetonford's Avatar
X2 on the pigtail I had the same issue replaced the pigtail and no more problem.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 01-16-2012, 08:31 PM   #7
yvesm's Avatar
Wally
We had 2 replacement regulators on our 2011 Rockwood and I finally replaced it myself with a regulator from Marshall. I also replaced the hoses from the tanks to the regulator.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 01-16-2012, 09:02 PM   #8
sherdep's Avatar
Just a little food for thought
The Regulator is $55 - (can always keep it as a spare if it doesnt fix the problem)
Pig Tails are about $15 each
on Camping world Website
Cost of Gas to fill up the TV and take camper to the Dealer depending on how far you live - I know for me it's atleast $100
Old 01-16-2012, 09:17 PM   #9
Location: No longer own a Forest River product, but enjoy the info on this site
X3 -- Had to replace the pigtail because of a leak in the hose. Other than smelling propane when we turned on the 'gas' we didn't experience any problems. Cheap fix, but was surprised to replace this part within the first year of ownership.
teamgl is offline   Reply With Quote
Old 01-16-2012, 09:24 PM   #10
Dave_Monica's Avatar
Wally...I've had the exact, same problems you're talking about. Ended up that I was opening the propane valve too fast. I reopened very, very slowly (about a minute to open the valve) and then all was good. Easy enough to try before you start replacing regulators, pigtails and such.
Good luck with it
Dave
