Old 05-19-2014, 12:58 PM   #1
Old Bones's Avatar
Question Pulsing water pump.
Not sure if this normal and our water pump has done this from day one.
When we use the taps in the bathroom sink the water pump pulses. There is a steady stream of water, but the pump has to keep building pressure. This happens with both the hot water and cold water taps and there aren't any leaks.
Is this normal for the water pump to pulse?
With the kitchen and bath tub faucets and flushing the toilet the pump runs continuous and maintains pressure.
Almost seems like the faucet in the bathroom sink isn't providing enough back pressure to the pump to maintain continuous water pressure. The bathroom sink faucet is also the closest to the pump.
2013 Forest River Surveyor SP296
Old Bones is offline   Reply With Quote
Old 05-19-2014, 03:22 PM   #2
2014 XLR 27HFS
dave961's Avatar
Search this site and Amazon for 'water accumulator'. Should solve your issue. Mine doesn't pulse, but I put one in after reading the benefits. Was very easy in my 27HFS.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 05-19-2014, 05:55 PM   #3
Iggy's Avatar
This is not normal and being it happens only in the bathroom sink I suggest you try this first.
Removing the bathroom faucet screen and turn hot/cold water on and see if it still does it. My bet is you have garbage built up there.
Just wash it out with full open valves.
If this doesn't work you may have to turn water off and check the faucet valve to see if it has garbage there.
No need to buy accumulator .
2012 Georgetown XL - 378TS 66K + miles
Old 05-20-2014, 05:46 PM   #4
Old Bones's Avatar
Not sure exactly what the deal was, but it must have been the bathroom faucet aerator.
I pulled the aerator apart and couldn't really see any debris in it, but it looked like it was assembled wrong.
I compared it to the one in the kitchen faucet and reassembled it differently.
The water pump is no longer pulsing when using the bathroom faucet.
Also not sure why they have 4 screens in both the kitchen and bathroom faucet aerators.
Old 05-20-2014, 06:49 PM   #5
Iggy's Avatar
GREAT.
And we all learn something new.
Thanks and glad the problem is solved.
Iggy
Old 05-20-2014, 07:00 PM   #6
Old Bones's Avatar
Originally Posted by Iggy View Post
GREAT.
Iggy
Thanks Iggy
The components inside the aerator appeared to be jammed together which I think was restricting the flow. Changed them around a bit and seems to be working good now.
Old 05-20-2014, 08:33 PM   #7
member
WOW! thanks I have had the same problem for two years now and couldn't figure it out. just read this post and went out side and checked my faucet and BAM! it was clogged cleaned and turned it on and pump ran great thank you very much
2019 Cedar Creek Silverback 31IKS
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 05-20-2014, 10:16 PM   #8
Old Bones's Avatar
Cool...good to hear you got it fixed up.
pump, water, water pump
