Old 07-04-2012, 05:08 PM   #1
pump sends water out external hookup
I have just purchased a 2007 shamrock hybrid. When I turn on the water pump the water shoots out the external hookup - even blows the cap off (doesn't fit great). My understanding is that there should be a valve that does not allow water to flow in the wrong direction to the external hookup but i don't see where it would be. I had a hookup for a filter but no filter so I just got a piece of hose to bypass. I have attached a photo of the plumbing system: the blue hose going out the top goes directly to the external hookup - nothing in between.
Any help is appreciated!
Name:	07 shamrock plumbing.jpg
jacks5canada is offline   Reply With Quote
Old 07-04-2012, 05:21 PM   #2
TURBS's Avatar
Your city water inlet check valve is stuck
Old 07-04-2012, 09:00 PM   #3
city water inlet check valve?
Thanks - I do not see where one is - there does not seem to be any valve between the pump and the city water inlet. There is a T on the line but it does not seem to be a valve. What does it look like and how do I unstick it?
Old 07-04-2012, 09:04 PM   #4
sherdep's Avatar
or missing
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 07-04-2012, 09:07 PM   #5
jtstromsburg's Avatar
It may (should) be part of the city water connection. If you remove that fitting from the outside or inside, you should see an extra thick fitting. That would be the check valve. You should be able to find one at most hardware stores and fix it easily.
at least that is how mine is
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-04-2012, 09:10 PM   #6
sherdep's Avatar
when you hook up a water hose to the inlet - does the water work ok?
I got this snip it from another site:
Concerning check valves, typically you’ll end up with three fresh water check valves; one at the cold inlet to the water heater, one at the city water inlet and one located at the outlet of the water pump. When on city water, you’ll want to keep water from entering the pump and when operating the water pump, you want to keep the water from spewing out the city water inlet. I always recommend carrying a spare backflow check valve just in case.
Below is what a metal and a plastic check valve will look like and there are other types as well
Old 07-04-2012, 09:12 PM   #7
caper's Avatar
The check valve is attached to the city water inlet. You will need to remove the inlet and replace with a new one. I had the same problem last year. It is an easy fix.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 08-22-2012, 04:00 PM   #8
fix for me - rubber stopper was backwards
The rubber stopper had a filter on it shaped like a bowl, it was hitting the valve and causing the city water to be always open....easy fix when I reversed the stopper!
pump sends water out external hookup Reply to Thread
thomasdt12 is offline   Reply With Quote
Old 08-25-2012, 06:31 PM   #9
Could these check valves effect water pressure inside, like shower sinks??
brad1103 is offline   Reply With Quote
Old 08-25-2012, 06:45 PM   #10
caper's Avatar
Our check valve was not working properly and we had low pressure in the trailer. replaced valve and now have great pressure.
Terry and Janet
2007 Ford F150
